high idle
at the same time i changed the tps and cleaned the TB i also replaced the pcv valve. i have adjusted the tps several times and i have gotten it to idle a little lower but is still too high. at first startup it will run at roughly 1300 rpms then after a little while it will drop down to 1000-900rpms. i have also significantly lost fuel mileage. haven't been able to find any vacuum leaks so far either. any suggestions?
Use a hand held vacuum pump/gauge to test each vacuum circuit/component. My '92 F350 passed all the spray carb. cleaner on the hoses/intakes tests I could throw at it but it still idled similar to yours. Once I used the vacuum pump/gauge I found numerous hoses were faulty as well as a rusted through metal vacuum reservoir.
Sounds to me like a vacuum leak. The vacuum lines age to a brittle state and when disturbed by working on the engine you can easily fracture them.
If that checks out okay (with a gauge as others have suggested), then I would check the IAC valve that's mounted on the intake. Sometimes they get clogged up or "stick".
If you're lucky like me, you're truck will eat one every 40-50,000 miles.
thanks for the suggestions. i will check out the vacuum lines in the next few days. hopefully this cold weather will get out of here. and the iac appears to be new. the previous owner must have changed it not long before i got it. it looks brand new and i cleaned it out when i had the TB off. if i unplug the iac the rpms do change so apparently it is working
