Ok, Maybe I'm Dsyl,Deslek,..turned around.
I have been looking for the block heater cord on my '07 F350 crew cab Offroad, and was about to conclude that I needed a new cord.
I found the OEM type has a spiral covering and a lot of attachnebt "nibs" and the cheapest cord looks like a re-used christmas tree extension.
So I sprung for the OEM after looking all over the front of the truck, but when I got to the plug from underneath.....It is NOT in the freeze plug at all, but back on the Starboard (right from the driver's seat) side of the engine.
And there IS a cord already there. It leads under the Starboard battery, and is coiled up nicely there.
OK HERE IS THE QUESTION: Is the 3 prong plug supposed to be on the starboard or port side? If Starboard, why dont they use all of the Nibs to secure the loom? My plug comes out even with the lights in the bumper on the Starboard side, but it does not use any of the nibs
Noone really knows what some of the designers at ford were drinking when they set up these trucks. Mine originally was on the port side, (left for you non navy guys), but when the end went bad, I bought a 3-prong black, heavy duty, outdoor extension cord and wired it in so that now it is located in the same opening as my starboard tow hook, (Non navy guys can figure that one out...hopefully). Where it is located is really up to you if you want to add to it, move it, or just replace it for something better. I know my oem 3 wire cord did look alot like what you mentioned...reused christmas tree extension. The cord I put in was of larger gauge wiring so it can handle the amps without problem as well as the road grime and weather. Just remember to wire correctly for the cord. white, black and green. Bad things can happen if it isn't wired right and you plug it in. :O
Always loved that right, left side stuff.....
My 1st response was... it depends on which way u are facing
So, for us non navy guys.... port is on the side the port is on ?
Which side is that ?>>>
Oh and all 3 of mine had the cord on the front passenger side of the radiator....
hard to see the black cord in the back hole covered in black tape, but it was there !
LMAO!
I race sailboats, and once sent a crewmember to the cabin to fetch something, told him it was in the Starboard setee. Mo-ron looks up out the companionway (facing aft) and says "My starboard or yours?".
Even my GF busted up laughing at that one...
And yes, we STILL give him rations of grief for that.
