Towing capacity lower with 5 sp than with E4OD?
Because of the clutch and the original warranty. Many people cant use a clutch without excessive wear when pulling a large load. And Ford didnt want to have to replace clutches when the truck was still under warranty.
And because the automatic has the torque multiplication of the torque converter.
How much weight did ZF rate the tranny for? I have looked and can not find it online.
You won't find that information because it doesn't exist. There is no such thing as the towing capacity of a transmission. They are rated by how much torque they can handle. There are lots of different factors that affect towing capacity of a vehicle and most of them have nothing to do with the transmission.
If you are good with a stick and don't mind replacing the clutch a little more often, then tow as much as the manual says regardless of what transmission you have.
on
That's a whole different thing, it comes down to the condition of the vehicle and the brakes in particular and total weight of the combo and road conditions, etc. And btw.. that 14000lb or 17000lb number is the combined weight of both truck and trailer.. not the trailer alone.
Realslowww
04-03-2015 08:45 PM
Fuelhog 5212
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-28-2011 08:10 PM
Gman75
05-21-2009 01:15 PM
