My Junk - Build Thread
#167
on
4.10's, with a close ratio diesel T19(4.02:1 first) and the stock BW1345. The gears are one of the many reasons I have been holding off on the C6.
The majority of my trail time is spent in 2nd low, which at the rev limiter is just a hair shy of 40 mph, but it will put along at 500 rpm just the same. Going to an auto is going to be a huge learning curve for me... I have never driven one off road, and have never owned one.
#169
on
Actually, that isn't the normal low first gear, the t18 is 6.32 and the np435 is 6.69. I only use first for crawling, it is mostly useless, even a 4:1 it really just makes for a bunch of rpm and no wheel speed. Everything you see in that video is in second, which is only 2.46.
With the stuff I've been breaking I am glad I waited on the 5.38's and locking the front. One twisted stub, crushed needles in both axle u-joints, blown up pass side locking hub.
I have 35 spline stubs, drive flanges and new spicer life series joints coming. Hopefully that will keep things together until I can go full chromo.
#173
on
Well after some maintenance I took it out, beat it and broke it again... Lol
I must have something weird going on with the engine mounts, as I broke the t-case adapter; which had come loose a couple times since I replaced the trans mount with a new stock one.
The factory 1345 is finally showing its age and the chain was making noises all day but it didn't puke its guts out.
All in all not a bad day for a truck that has been dormant for almost 2 years.
Flogging the 460 pig in hole one on Contact Bay:
I may or may not have had a tree jump out and get right in my way... Lol
Contact bay last hole/hill bypass.:
#175
on
I'm going to try a new set of stockers and a limiter strap on the drivers side. The current set of mounts is from the 97 that donated the block so there is only around 60k on them but they are still pretty old.
All else fails I'm going to probably go with Autofab's setup. Not big on solid mounts in a street rig.
At the end of the day my issue may be gears. I'm hoping its not so, budget is not there for them.
#176
#178
#179
on
Solidifying the stockers isn't going to help, the movement is from the drivers side moving the bolts in the slots in the frame perch.
I can't say I've seen that before and the factory bb mounts have 2 studs to the small block and all the conversion mounts one.
Going to have to go with a limiter strap or a full blown aftermarket setup like autofab's that has its own frame towers.
stang_me1990
05-31-2012 12:27 PM
wizzy214
62
07-02-2010 12:14 AM
