Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-14-2009, 07:15 PM
bigtimebubba bigtimebubba is offline
Garage is empty, add now
bigtimebubba is starting off with a positive reputation.
hella 700ff install
Can someone help me on the install of these hella driving lights.
The directions they include in the box leave a lot to be desired. It doesn't help that this is really my first electrical install.
I have a 99 superduty. I hooked up all of the wiring harness in the engine bay of the truck. I wanted to make sure it worked before running the switch to the interior. I can't get any power to it. I got so frustrated that I pulled the entire harness and just left it on the counter in the garage.
Has anyone done an auxiliary light install that can help me out.
  #2 (permalink)
Old 12-14-2009, 08:27 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
1989 Ford F-250
Franklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud of
I downloaded the manual. Do you want to try to install it again and then go from there?
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 12-14-2009, 09:41 PM
Yes. Let me try it again tomorrow.
So each light needs to be grounded correct? The blue wire from each light.
Red wire on the harness plugs into the positive on the battery terminal
Green wire tap into on of the headlight wires. I chose to chanel lock the green wire on the headlight harnes
Yellow goes from the relay to the switch
The switch grounded. The blue wire
The relay grounded. The blue wire
Black wires from the lights connected to the black wire of the relay harness and goes to the relay.
What am I missing. Where should I be fastening the grounds for the lights, relay, and switch?
  #4 (permalink)
Old 12-15-2009, 11:00 PM
Franklin2's Avatar
1989 Ford F-250
So each light needs to be grounded correct? The blue wire from each light. yes
Red wire on the harness plugs into the positive on the battery terminal yes
Green wire tap into on of the headlight wires. I chose to chanel lock the green wire on the headlight harnes This should tap into the lowbeam if they are fog lamps. If they are driving I guess you could tap into the highbeam wire. Whatever wire you tap into, they will only work when that circuit is on
Yellow goes from the relay to the switch yes
The switch grounded. The blue wire no. No grounding blue wire from the switch
The relay grounded. The blue wire yes. To terminal 85
Black wires from the lights connected to the black wire of the relay harness and goes to the relay. yes. On terminal 87
What am I missing. Where should I be fastening the grounds for the lights, relay, and switch? Fasten the grounds to any metal piece on the body. Make sure you scrap the paint away.
__________________
Dave F
Tags
2010, 700, 700ff, 700ffs, duty, f150, f250, guide, hella, install, installing, instillation, super, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
