Glow Plug Wire Harness
Old 12-14-2009, 01:57 PM
Old Whitey's Avatar
Old Whitey
Old Whitey is offline
Hello all,
This is my first time posting and also first time diesel ownwer. I have a 1987 F-350 6.9L diesel, 5 speed manual trans, single axle.
I went to relace a couple bad glow plugs; when I pulled the plug wires off they pretty much decentigrated/crumbled in my hands. Is this common? Now I'm having a hard time finding a place that carries the glow plug electrical harness. Called Oreileys, they couldn't get it. So, called Ford dealer they could order it but, would cost around $500. Sounds a bit expensive. Any sugestions on other places to order from? Thanks in advance.
Jim
Old 12-14-2009, 02:03 PM
Links56's Avatar
Links56
Links56 is offline
Welcome! Can you just put new ends on the wires that are there? Just cut them back a ways and splice a new piece of wire and spade connector. Just make sure you use the same gauge wire because the current these draw. Otherwise you could find a used one I guess. You better grab a tub of Vaseline if you are going to go to the dealer.
Old 12-14-2009, 02:33 PM
Old Whitey's Avatar
Old Whitey
I'll look into that. Should I ask the parts store for a specific spade connector or will any kind work as long a I use the same gauge wire?
Old 12-14-2009, 02:38 PM
Fishin76's Avatar
Fishin76
Fishin76 is offline
You could make your own. Not that hard or expensive. Just time to complete it. Radio shack for wire and connectors. Re-use the controller plugs, or get ring terminals. Just keep track of your wire colors.....
Old 12-14-2009, 02:41 PM
Links56's Avatar
Links56
Links56 is offline
Well just make sure it fits the glow plug of course. Just have them bring a new glow plug out and find the spade that fits it.
This is what I would do...
Get the spades and the right gauge wire. Then solder the spades to the wire. Then slip a piece of heat shrink tube over the solder connection and shrink it with heat. Now you will have a so called pig tail. Just make 8 of them and cut the harness back until you have good wire then solder the connection or crimp it with a butt connector.
They also have butt connectors that have heat shrink tube on them already.
You don't have to solder it if you don't want to. I just would if it was me as an extra measure for good connection and so it won't come apart from vibrations or anything.
hope this helps.
Old 12-14-2009, 02:44 PM
Fishin76's Avatar
Fishin76
Fishin76 is offline
I like the way you think, Links56...
x2 thats a good way to do it.
Old 12-14-2009, 02:55 PM
Old Whitey's Avatar
Old Whitey
Thanks for the suggestions. I'll give it a shot.
Old 12-14-2009, 04:49 PM
farmert's Avatar
farmert
farmert is offline
The 87 should have the bullet connectors, not the spade connectors on the glow plug end, if I remember right.
Old 12-14-2009, 05:07 PM
Links56's Avatar
Links56
Links56 is offline
huh, that may be. I don't know. My 87 has spades on it.
Old 12-14-2009, 07:30 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
87 was a strange year.
Seems both the old style and new style glow plug system was used in 87.
Do your glow plugs have flat blade terminals or the round pin terminals on them?
Old 12-14-2009, 08:42 PM
Old Whitey's Avatar
Old Whitey
They are round and shaped like a bullet. Will that make a differance when choosing which connector to buy?
Old 12-14-2009, 09:46 PM
JD_F250's Avatar
JD_F250
JD_F250 is offline
Ive got an 87 with the bullet style connectors. I too had ALL of my nice little connector covers shatter into millions of pieces...well actually they turned into dust. i pulled one GP out and took it to radio shack. just figure out what will fit and grab eight. well 9 if you cant hold on to stuff and you hear it fall to the ground and cant find it. hmmm sounds familiar. then cut and splice and your set.
Old 12-14-2009, 09:57 PM
9473's Avatar
9473
9473 is offline
I see these guys carry the replacement bullet connectors:
<style></style>7.3 L Ford Diesel Fuel Injectors Fuel Pumps Accessories
Old 12-15-2009, 05:55 PM
Dave Sponaugle
That and some members have used a bullet connector with good results as well.
Can't remember what size they used though.
I have to wonder what Ford gave you a price for.
I bought a 93 engine wiring harness for 150 dollars 4 or 5 years ago.
If you have the new style glow plug system, that is the same harness you would need.
Old 12-15-2009, 06:32 PM
9473's Avatar
9473
9473 is offline
Ford has discontinued the GP harness, at least for my truck. That's what brought me here so lemonade from lemons. Someone here recommended the replacement bullets. They are NAPA #784353. I've cut the wire at the OEM connector then crimped and soldered the new bullet. Before connecting the bullet I slid a piece of shrink tube and the bullet insulator on the wire then slid it up and heated. It'll work fine my only reservation is whether the nylon cover for the bullet will hold up. Time will tell...
Quick Reply: Glow Plug Wire Harness
