01 Turbo Setup. Perfect for early 99 swap
Category: Engine - Intake/Fuel
Price: $300
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): NSX
Item Condition: MS
Shipping Information: Item can be shipped
Engine: Part suitable for diesel truck
Can you explain more about the "Perfect for early 99 swap"?
I do have early 99 7.3 Powerstroke with need for a turbo. Would that fit?
I assume that would be update to newer model of turbo?
yep early 99 turbo's are different i believe only other thing u'd have to have is up pipes. this is everything u'd need on the turbo side. Turbo,Pedistal,Spyder,Intake runners and boots from intake runners to spyder.
Do you have a picture?
Per your explanation I would have to buy additional up pipes to make it working.
Would you know if that is straight bolt-in swap, or more modifications would be required?
If anyone is wondering the differences they can give me a call and I can walk you through it. I have done a couple swaps and it does make a nice difference, as well as allow you to upgrade your turbo later on to a 38R if desired. I would recommend buying new Plenums as they are inexpensive and you don't want to find leaks after your all done.
Also, this is a good price for everything and saves you the time of trying to piece everything together.
Yeah, it really seals, LOL. I had to practically destroy the last set I got off an early 99 because they were on there so well.
