What colors do I paint an engine for a 1965 F100 352?
Old 12-07-2009, 09:40 PM
zepplyn's Avatar
zepplyn
zepplyn is offline
Help!! I need advice on the correct Original paint colors to paint a rebuilt 352 engine going into a 1965 F-100. From what I have gathered, it seems the original paint scheme was a Black block & intake manifold, with Gold valve covers. Any advice???
Old 12-07-2009, 10:16 PM
Bill W's Avatar
Bill W
Bill W is offline
when your done it should look like this. and Welcome to FTE
Old 12-07-2009, 10:38 PM
Bdox's Avatar
Bdox
Bdox is offline
Welcome to FTE zep!
Old 12-08-2009, 03:45 AM
camperspecial65's Avatar
camperspecial65
camperspecial65 is offline
block,heads, and rest of engine except valve covers are black...I think water pump and alt. mtg spacer is natural, valve covers are gold as shown in the pic in prior post...
- cs65
Old 12-08-2009, 09:28 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Welcome to FTE
You are 100% correct on the engine paint scheme.
However, if this was a 1966, the entire engine would be painted Ford Corporate Blue...including the valve covers.
1952/65 OHV I-6's and V8's: Ford painted the blocks one color, the valve covers another color.
The valve covers were painted specific colors, because...this is how Ford mechanics, outside repair shops, garages, body shops and etc. ID'd what sizes the engines were...I kid you not.
Every year, FoMoCo sent out to the dealers...charts showing the myriad valve cover paint colors, which showed what size engine each color represented.
The dealers then passed them out to all their wholesale accounts.
The problem was...the same engine in a car may/may not be painted the same as in a truck. Again, I kid you not.
Examples: 1965 F100/350 352: Black engine, Gold Valve Covers / 1965 Galaxie/LTD 352: Black engine, Blue Valve Covers.
1965 289 2V installed in Galaxies, Falcon's, Fairlanes, Mustangs: Black engine, Gold Valve Covers! (sigh)
Old 12-08-2009, 11:26 AM
civicmindeddogooder's Avatar
civicmindeddogooder
civicmindeddogooder is offline
What about 240 ci? Color ofr 65 f-100
The color scheme interests me because my 240ci has never been changed and the block is black and the valve cover is black - the valve cover has a sticker which I can't read but would like to replace when I rebuild the engine (whenever that may be). Is this the proper color scheme for the 1965 240ci in a f100 2wd manual? If so, what did the sticker say and are replacements available? The sticker on the ac says 240 and 150hp.. Thanks.
Old 12-08-2009, 05:52 PM
NumberDummy
The block is black, but what color the valve cover is...I forget. It could be black, or blue, or red.
Old 12-08-2009, 06:01 PM
Bill W's Avatar
Bill W
Bill W is offline
my 1965 240ci engine is also all Black.
Old 12-08-2009, 07:03 PM
NumberDummy
Here's the answer from Bill W(ilson) to y'all, and...to this Bill Wilson...who couldn't remember what color the valve cover was.
Old 12-08-2009, 07:30 PM
chaser1602's Avatar
chaser1602
chaser1602 is offline
The radiator should be silver?
Old 12-08-2009, 07:33 PM
NumberDummy
Hi-yo Silver away!
The radiator is supposed to be painted black.
Old 12-08-2009, 07:52 PM
camperspecial65
yup...at that theres a special radiator paint...to stick to it...
- cs65
Old 12-08-2009, 08:00 PM
Bill W's Avatar
Bill W
Bill W is offline
the rad does look silver in the picture... kind of... but it's not
Okay Squire Don, tell me what is special about the paint for a rad? high temp?
Old 12-08-2009, 09:07 PM
OldHarley's Avatar
OldHarley
OldHarley is offline
My '66 F100 Custom Cab 352 has a black block, heads, etc. Don't know about valve covers since they have been chromed.
Of course it may have been repainted or swapped at one time, but I suspect it might be due to an August 1965 build date.
Any ideas if it would be the proper color to leave black?
Old 12-08-2009, 11:28 PM
IsoGrifo's Avatar
IsoGrifo
IsoGrifo is offline
I coulda sworn the 240 was black with blue valve covers...
Quick Reply: What colors do I paint an engine for a 1965 F100 352?
