Has anyone had any experiance with the EGR delete kit from this company? I have looked on their website but it is not very informative. I am looking to do a EGR delete and the shop I am looking at said that they use their kit. I have another shop that uses the Liberator, but that is 1 1/2 hours away. Thoughts anyone?
This is the kit that is on my truck. I can't tell you much about it though. I know I am leaking coolant out the back of my engine now near the EGR cooler area. Shop put it in. I am regretting it now though.
What kind of quotes did you get from these two shops....contemplating on whether I DIY or have DIFM?
This particular shop wants 8 hours @ $98/hr and I think it was $700 for the kit. Other's wanted $600 and 7 or 10 hours. The shop with the liberator was $590 plus 7 hours. Keep in mind these are Canadian dollars.
There were two kits i chose between, liberator or River City Diesel. Both are fine products and well made. If i had to do it over again I would have installed the upgraded cooler and purchaces a turned (SCT). If your don't have to replace the cooler for leakage then just use the tuner to deal with EGR valve operation. Since i installed the kit the truck has not acted very well running very rich, now 7.5 miles to the gallon. Breaking the connections at the turbo will just create leaks. I am about to go back to EGR valve with the upgraded cooler. Quite frank i am pulling my hair out. If your truck is newer than an 05 you have to buy the a tunner, but just for the EGR cooler delete kit you should not have to pay more than 450.00. Easy enought to do it yourself just be patient. Any questions just holler.
Gearloose1 at the bottom has the best idea, if you do not have to replace EGR Cooler due to leaking this is the route to take. Effectively does the same as the full kit for a fraction of the price.
hey guys, unplugging the egr by the intake will keep it from opening it's free but will set the check engine light off.also you can check out elite-diesel i have an egr delete pipe and block off plate... and a buddy of mine has their complete egr delete kit.
Dave
Well that is what I am trying to avoid by deleteing the EGR and cooler alltogeather is it leaking and leading to other costly repairs ie. head gaskets. I tow a 40' fifth wheel during the summer that grosses about 13,000 lbs when fully loaded and I am concerned about getting stranded someplace. So it is more of a preventative measure and peace of mind for me.
When i installed the EGR Cooler bypass kit, it had me remove the Egr valve. Doing this has put the truck into a safe mode. Running very rich. Most important thing is to make sure you can leagally remove the system, I live in Alaska so not an issue here. On this 04 ford that the kit is installed on it was only suppose to give a soft code, my scanner is picking the deletion up as a continuous DTC. I would put in this Bulletproof Upgraded cooler and shut the EGR valve down using a SCT tuner. Or Delete the Egr cooler, install straight up-pipe that will come with kit, and install Turbo back 4" exhaust, then use tuner for desired settings. If the truck i installed the delete kit on was mine, i would do the ladder. May be a little noisier but that sucker will breath.
I'm not sure you can "legally" remove emissions equiptment from a vehicle anywhere in the U.S. Maybe Alaska is different? My plan, when I'm done procrastinating over it, is to do the stealth delete. AFAIK thats the same as welding in a freeze plug in the end of the cooler so everything "appears" to be there and functioning.
