75 302 breakerless no spark
Folks, my issue is no spark, 75 302 breakerless ignition. I have 12v at the coil. I have replaced the coil and computer (pulled from my working 79). The dist is turning. I pulled the dist and put in one from a working junker from two years ago. The engine cranks fine but no spark at the coil. I checked for spark going from coil wire to a ground and with the coil connected using a timing light (no spark, no light) I have replaced the coil wire with one from my working 79. I even went so far as to pull the coil & comp from the 75 and it works in my 79. The only thing I haven't swapped is the dist from my 79 to the 75. Any thoughts would be appreciated.
mevans1955
21
06-04-2016 08:28 PM
