1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2006 F350 seat belt retractor
Old 11-30-2009, 05:09 PM
FD5150's Avatar
FD5150
FD5150 is offline
I am having a problem with my front seat belts on my '06 F350 crew cab 4x4. Both sides won't release properly. The problem seems to occur more often when the truck is cold, but it also happens at other times. I have the truck at the dealer for this problem, as well as a few others. The dealer just called me and said it was going to be $590 to replace both seat belt retractors. The truck has 65000 miles on it, and the dealer says the belts are covered until 50K. Has any body had a similar problem? Does any one know where I might get the retractors ( the dealer says they are $ 190 left, and $ 210 right ), and how difficult they are to install? Also, shouldn't this safety issue be covered by Ford? Any help would be appreciated, Thanks!!!!
Old 11-30-2009, 07:56 PM
mrford60's Avatar
mrford60
mrford60 is offline
The seat belt retractors are not hard to replace, you have to take off both the front and rear sill plates, then take a T-50 socket and remove the bottom and the top atttachment point of the seat belts. then pop off the trim piece that covers the inside of the B piller and that is where the retractor assm is(its part of the seatbelt) and it is attached by a T-50 bolt also, and it has wires pluged in to it. un plug and replace. go to tascafordparts.com for a great deal on parts. there cost on those are around $100.00 ea. good luck
Old 11-30-2009, 08:02 PM
FD5150's Avatar
FD5150
FD5150 is offline
Thanks for the info.!!!
Old 04-13-2010, 11:17 PM
bondobob65's Avatar
bondobob65
bondobob65 is offline
My 2001 is a royal pain at times both side do not retract evenly or sometimes at all
Michael McIntyre
04-17-2017 11:40 PM
jvmcc
19
03-05-2017 10:37 AM
GR8NW
04-17-2016 11:48 PM
KNNTHWLSN
New Member Introductions
02-05-2016 11:50 AM
RecycledTeen
09-09-2012 10:12 AM
Quick Reply: 2006 F350 seat belt retractor
