Computer Location
Old 11-26-2009, 11:46 PM
nextalcupfan's Avatar
nextalcupfan
nextalcupfan is offline
Computer Location
Ive got a 1995 f-150 5.0L 5-speed extended cab.
The PO told me that the PO from him put a HO Mustang engine in it (in mexico)
i want to see if the computer is a mustang computer or the stock truck computer (i will also see if the block is a mustang block or not)
now i belive the computer is behind the drivers side kick panel so while i was doing some subwoofer wireing i took the kickpanel off and met a 1/4 in thick plate of steel that the e-brake ataches too, and it looks like it goes all the way from the floor to a metal piece under the dash next to the steering colum.
there was about an inch gap at the bottom so i looked up and i thought i saw the side of the computer
ive been scouring FFI website but i cant find anything on it so any help would be apreciated
Old 11-27-2009, 03:48 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
You are, I think nearly on the right track, the computer is where you think it is except you get to it from under the hood.
There is a computer location guide somewhere on this site but I can`t remember where exactly it is.
Old 11-27-2009, 04:50 AM
lew52's Avatar
lew52
lew52 is offline
Yes the computer is on the drivers side & comes out from under the hood . The HO will run on either computer . Your 95 is a roller motor so the only difference in the motor will be the cam & depending on the year of HO it will have forged pistons . The block , crank & heads will be the same ... Lew
Old 11-27-2009, 10:42 AM
nextalcupfan
First of all thanks for the quick replies u 2
second, ive done alot of research on the HO line of engines and i had read that FORD made 2 or 3 different versions of the HO.
2 were for mustangs (forged or cast pistons like u said lew) and one for trucks which had flat tappet cams for more torqe. (of course this could be wrong)
There are 3 reasons why i want to check
1. The truck will surge under par-throttle it's not much but its enough to be annoying.
2.The truck will not idle right After its warmed up it will idle for 30 sec to a minute at 700 rpm but for no reason it will go up to 850 or even a 1000 RPM and hold there, but if i bump the throttle it will go back down to 700 for awhile
(i have replace the TPS and IAC and it seemed to help a little with both above problems)
3.Suposidly(sp?) the motor was swapped at about 160k and for some reason the person doing it put the original 1995 Spark plug wires on it.
And the plugs looked pretty old too but the cap and rotor looked newer. (tune-up done at 210k)
which that makes me suspicious of an engine swap at all exept for the fact that at 212k its the best sounding engine i have ever driven (thats not sayin much though)
phew thats along post...
Old 11-27-2009, 11:00 AM
lew52's Avatar
lew52
lew52 is offline
Yes they made the early carbed 302 HOs in the mustang , then i think in 88 the cam changed in the HO & were EFI to 94 , they made a 351 HO for the truck with a flat tappet & carb , thats all i know of ?? .. Lew
Old 11-27-2009, 11:16 AM
nextalcupfan
well my motor does have the 351W firing order but i think its to small to be a 351W
and the early HO mustangs were Speed density (86-88?)
the problem is i want to put a chip in it or something like the TwEECer unit mentioned on Ford Fuel Injection site
Old 11-27-2009, 11:18 AM
nextalcupfan
oh and could you explain exactly how to remove the computer from under the hood
Old 11-27-2009, 12:20 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
Old 11-27-2009, 12:32 PM
lew52's Avatar
lew52
lew52 is offline
The 94 & up 302s are roller motors so they have the same firing order as the 351 & HO , Remove the bolt & nuts that hold the harness on and hold the computer in & slide it out , its a tight fit but it will come out , you may have to remove some of the screws that hold the fender well in or just press down on it to get the room you need ...
Old 11-27-2009, 12:42 PM
nextalcupfan
ya i just went out to look and i saw the harness with the bolts that go into the firewall.
i just ran a code test and here's what i got
KOEO: 111
CM: 111
KOER: 111 (WOT test was preformed)
my book says most 1992 and up fords use 3 digit codes and the only mustang computers that use SD are from the mid-late 80's
so my computer is most likely the original, but im gonna check anyway
Old 11-27-2009, 01:08 PM
lew52's Avatar
lew52
lew52 is offline
Your 95 is mass air right ??
Old 11-27-2009, 03:42 PM
nextalcupfan
nope MAP
wanted MAF tho
Old 11-27-2009, 04:02 PM
lew52's Avatar
lew52
lew52 is offline
Thats strange, i thought all 95s were mass air , they started in 94 ????
Old 11-27-2009, 06:32 PM
nextalcupfan
i think some were MAF in 94 and 95 but i think all are MAF in 96
Old 11-27-2009, 08:11 PM
brett12396f150's Avatar
brett12396f150
brett12396f150 is offline
I thought my 94 was MAF.....u sure its not?
Quick Reply: Computer Location
