electric locker
yeah they dont seem to make them, however detroit lockers or better limited slips without clutch packs are out there....here are some for you to take a look at.
Ford 9.75 Differential Positractions Auto Parts: AUBURN,AUBURN GEAR,LIMITED SLIP,POSI,POSITRACTION,DIFFERENTIAL,FORD 9 3/4,FORD 9.75,DETROIT,DETROIT LOCKER,LOCKER,DANA,DANA SPICER,SPICER,EATON,FORD,TRUE TRAC,TRUETRAC,AG 542090-HP,DET225C-194,DS 73106
hope this helps.
It is odd that there are no real e-lockers out there for the 9.75. I guess your only option is to take the rear pumpkin and beef up the limited slip. Then if you have 4WD you could take the 8.8 front end and put an e-locker in that.
~Jstnromero
On Edit: We have a Detroit Truetrac on my dad's superduty and it performs wonderfuly. It is locked when we need it and unlocks when turning. It is a very solid unit that has no clutchpacks to deal with so pretty much zero maintenance other than changin the fluids at the required times.
hope this helps.
~Jstnromero
93-331-29PSI
6.7L Power Stroke Diesel
55
12-14-2015 06:36 PM
A Rodder
11-20-2015 01:32 PM
