Need a clutch pedal bracket for a '55 F100
<!-- / icon and title --> <!-- message --> <!-- BEGIN TEMPLATE: ad_showthread_firstpost_start --> <!-- END TEMPLATE: ad_showthread_firstpost_start --> Hey Guys!
I'm changing from a T98 4 speed to a T86 3 speed with a R10 overdrive. I looks like my clutch support bracket from the 4 speed won't work on the 3 speed. Any ideas? Are all the 3 speed clutch pedal brackets the same, or do I need to find the specific one for this trans?
Where does it mount, what is its function?
Received 4,135 Likes
on
i have to find it daddyo , but i got the bracket in question guy . i did the opposite of you , i went from the light duty 3 speed to a t98 four gear in my 53 . no they are not the same . i'll trade you for the one from your t98 for mine . is that agreeable to ya ??? i even got the 3 gear , the yoke , the driveshaft all of it from when i swapped here . if you and i were closer i'd trade it all to you for your stuff . and yes from the bellhousing back my 53 and yer 55 is the same stuff .
There is no bracket for the T86 for your truck because Ford did not use that trans for '53-'55. You will have to fabricate some kind of bracket. here are a couple of pictures with various 3 spd trans. for the '53-'56
you got a different 3 speed than mine had . so i dont think it's gonna be feasible for my part to fit . it may take me a bit , due to the work schedule and i got stuff scattered around in a couple different places , and a 91 bird in peices in my garage . so be patient and after i get done putting up xmas lights this weekend i'll search and see what we come up with ...................... you know after looking again i recant , that bracket is very much the same as mine , i will look !!!!!!!!!!!!!!!!!!!
