Extended Cab on 133 Inch Frame?
Has anyone put an extended cab on a short frame? I have a 133 inch wheel base frame and would like to put an extended cab on it. As I see it I have two options, install an extended cab and cut the bed down or extend the frame. I have read before the admonition about cutting and welding ford frames and I don't want to hinder towing capacity (it is a superduty frame) so I am a little hesitant to do that although I have the equipment to complete the task. If the extended cab will fit on that short frame, I would feel better with just shortening the bed. This would affect gooseneck towing some but I wouldn't compromise the frame. Any thoughts?
It has been done. A guy put an x-cab on a 133 frame and shortened the bed. Then put a 4 door cab on and shortened the bed even more.
EDIT: here is his build https://www.ford-trucks.com/forums/8...swap-pics.html
Thanks for your help. I think I'm going to try it. It will be an interesting project at least and better than cutting the frame. The frame I have is a 4wd superduty. The 4 door option sounds interesting. That would probably make the bed about 5 feet? Since I have a blank slate limited only by the NP435 Transmission and larger diameter tires, what year xt cab or 4 door cab would look best?
I have a friend that lives close to me who owns a fab shop and lenghtens and shortens frames all the time.if it's done corectly it will be stronger than factory.as soon as I find a flairside bed,he's going to shorten the frame on my 81 so I can change it to a flairside.he did this to his daughter's truck and did a great job.
If it has a D60 front axle it is a F350
If the rear axle has a plug on it for a ABS sensor it is 87 or newer, if not then it is 86 and older
red450ih
03-08-2015 04:33 PM
nefftrooper
11-19-2010 02:18 PM
jnd1959
Fifth Wheel & Gooseneck RV Towing
12-01-2009 11:28 AM
