econoline vin
Old 11-15-2009, 12:07 PM
dirtyjoe's Avatar
dirtyjoe
dirtyjoe is offline
econoline vin
  1. hi new to site need help on econoline p/u vin.F14AH832374 /90 M E 142 289 C 07 04930 129 4000 71 THANKS.
Old 11-15-2009, 03:39 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by dirtyjoe
hi new to site need help on econoline p/u vin. E14AH832374 / 90 M E142 289 C 07 04930 129 4000 71
Welcome to FTE
1961 thru 1980: Econoline VIN's begin with an E, not an F.
F is the designation for an F Series Truck.
The following decoded info is for an Econoline VAN, not a pickup. *
E14 = E100 Van (E10 = Pickup)
A = 240 1V I-6
H = Lorain OH Assembly Plant
832734 = 1966, assembled in March 1966
90" Wheelbase
M = Wimbledon White
E142 = E100 Van / 4930 lbs. GVWR (E102 = Pickup 4930 lbs. GVWR)
289: 2 = Medium Blue Crush Vinyl & Medium Blue Match Stick Vinyl // 89 = 89A Econoline Van
C = Ford Type 3.03 3 Speed Manual all Syncromesh Transmission
07 = Ford 9" Rear Axle / 3.00-1 / Non Limited Slip / 3300 lb. Rear Axle Capacity
4930 lbs. Gross Vehicle Weight Rating
129 net HP @ 4,000 RPM.
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the vehicle from.
* This info is for an Econoline VAN, not for a pickup. An Econoline pickup is body style 87.
Here's why this info is in-correct: The Warranty Plate is located on the left door face. People swapped left doors due to damage with used doors.
99% of the time, they did not install the original Warranty Plate on the replaced door.
If you compare the VIN on the registration with this VIN from the Warranty Plate, you will see that they will not match.
Old 11-15-2009, 05:24 PM
dirtyjoe's Avatar
dirtyjoe
dirtyjoe is offline
thanks for the info,previous damage to left front!!! no registration.where might i find the vin#?
Old 11-23-2009, 06:07 PM
vanishingbreed's Avatar
vanishingbreed
vanishingbreed is offline
look at the back of your doghouse. If there is a hump the vin number will be there. If it doesn't have the hump you need to take the front of the dog house off and clean off the gunk and you should then see the vin on the floor. I had the same problem with my 65 Econo Van.
Old 11-24-2009, 10:17 PM
66gpw's Avatar
66gpw
66gpw is offline
I said in another post the cross brace at the back corners behind the taillights. either the left or right. Also has the serial number stamped on them. Usually it is the left one.
Oz Econoline
02-19-2015 04:04 AM
JAYGUILD
07-27-2013 03:18 PM
Trado11
07-14-2013 01:09 PM
spartan986
01-17-2011 08:44 AM
briank
01-31-2010 09:24 AM
Quick Reply: econoline vin
