Who here has blow up a front hub Bering?
I know it's off topic but I know some of us just stay down here in the 7.3 fourm
Well I can say I did I have been trying to figure out where this high pitched squealing noise has been coming form and I think I found my culprit. The bearings are chewed up bad and it looks like it just ran out of grease in there. When i separated the hub form the axle I had stuff fall out that I thought was just mud nope it was metal shaving's
Here are some pics of the carnage
So Is OEM the best for this or is there an after market hub that is better?
Thanks
Nick
Thanks
Nick
Timken is who Ford uses. This is what I bought Amazon.com: Timken 515020 Axle Bearing and Hub Assembly: Automotive
I just replaced mine a month ago. I went to NAPA (not sure if you have NAPA there) and they had two options. I bought the more expensive ones. The package I got had the studs, nuts and o-rings included already. It looks like the Amazon ones don't. On the other hand, I had expected to have to buy the studs and o-rings separate, so if it was me, I'd probably go for the Amazon ones and order the studs and o-rings at the same time. If you can't find studs, you can remove the old ones and reinstall them if you want.
I just found this and bookmarked it this morning:
Timken WHEEL HUB ASSEMBLY ford F-250 SUPER DUTY 99 auto:eBay Motors (item 130343065957 end time Dec-08-09 09:50:11 PST)
Ford F250 F350 Super Duty 4x4 Hub Wheel Bearing 2002:eBay Motors (item 150357914356 end time Dec-06-09 10:08:33 PST)
99 00 FORD F250 SUPER DUTY FRONT WHEEL BEARING HUB 4WD:eBay Motors (item 270402890764 end time Dec-01-09 09:50:57 PST)
Edit : Removed Wrong Link: This is correct LINK
Be prepared for those studs to not want to come out. Most folks who do this just get the studs. It's not worth the effort trying to remove the old ones for the price of new studs.
