Oil pan drain plug problem
Old 11-14-2009, 09:56 AM
FSJ-EARL's Avatar
FSJ-EARL
FSJ-EARL is offline
My oil pan drain plug is about a 1/4 turn away from being stripped out. I have a slight leak and want to address this ASAP. What size plug comes stock and what size can I go to for an oversized plug? Any other thoughts, ideas, or suggestion in regards to this matter? THANKS!
EARL!
Old 11-14-2009, 10:02 AM
SuperDoodie's Avatar
SuperDoodie
SuperDoodie is offline
Did you use a new washer?
I put a new washer on every other oil change and have had no leak problems..
Just my .02 pennies worth
Old 11-14-2009, 10:04 AM
FSJ-EARL's Avatar
FSJ-EARL
FSJ-EARL is offline
No, I did not use a new washer, not sure that it would make a difference since the hole in the pan seems to be closed to being stripped out from the previous owner being a bit too over zealous with the tightening on the drain plug.
Old 11-14-2009, 10:08 AM
big poppa's Avatar
big poppa
big poppa is offline
Maybe double up on the copper washers would be my suggestion. Maybe get yourself a Fumoto drain valve from Clay, this way you tighten it down and its done.
Old 11-14-2009, 10:15 AM
FSJ-EARL's Avatar
FSJ-EARL
FSJ-EARL is offline
Has anybody actually put an oversized drain plug in their oil pan?
Old 11-14-2009, 10:27 AM
megawatt00's Avatar
megawatt00
megawatt00 is offline
If it is really fubard you can use one of these:
OIL DRAIN PLUG by Motormite - Part 5707897 - Advance Auto Parts
Old 11-14-2009, 11:35 AM
guitarpicr's Avatar
guitarpicr
guitarpicr is offline
Second the fumoto valve like Mike said then no more removing the plug, & easy oil changes.
Old 11-14-2009, 12:11 PM
FSJ-EARL's Avatar
FSJ-EARL
FSJ-EARL is offline
I would like to do the fumoto but I am worried since the threads in the pan are not good.
Old 05-11-2015, 07:09 AM
FSJ-EARL's Avatar
FSJ-EARL
FSJ-EARL is offline
Bumping this back to the top. I know that this is old, but does any ideas or suggestions? Thanks!
Old 05-11-2015, 12:06 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
I would find a Fomoto valve that was a slightly larger thread size and re-tap the plug to that size and be done with it.
Old 05-11-2015, 01:46 PM
Ford79's Avatar
Ford79
Ford79 is offline
I've done quite a few oversize plugs. I am unsure of the stock size of the drain plug on these trucks. The oversize plug will cut new threads as it is tightened in the pan.
Old 05-11-2015, 02:19 PM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
Did not see it mentioned, but important to know: replacing the oil pan requires removing the engine.
Fumoto FTW!
Old 05-11-2015, 02:32 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
I think I'd start with a new, standard size drain plug. It's far more often the threads on the plug that are hosed than the threads in the pan. Most drain plugs are softer than the threaded insert in the pan and therefore, get buggered up first.
Old 05-11-2015, 03:46 PM
DND58's Avatar
DND58
DND58 is online now
What he said. Try a new original plug first. I had a pesky drip with original, but went with Fumoto for convenience. Problem solved.
Old 05-11-2015, 08:56 PM
KJNDIVER's Avatar
KJNDIVER
KJNDIVER is offline
if it was on its last leg when the thread started, how did you manage to make it 6 yrs later without doing anything to it? Has truck been parked? Has the oil not been changed in 6 yrs? If youve been driving and changing oil all this time later, maybe its not as bad you think it is. But i recommend the fumoto, thats what i got, install it and be done with it....
Quick Reply: Oil pan drain plug problem
