Plow ID Help.. Picture!
No but you will need to hoop too. Are you looking for used in the papers or going to some plow place. Meyer Products: ST & TM Series Plows You should be bale to look up what you need there.
Not sure of the area your in but I do see complete set up in the paper from time to time. You will need the hoop, pump and electric, blade, rams, and hoses. For the life of me I can not recall the name or series of the blade / moldboard for this type mount.
Part of me is saying this is the 1st gen of the quick hook up. This was before the whole thing was one unit that came off the truck. the Blade is still set up the same at the original pin set up however you could pull the hoop off removing the arm, pump and brackets off the front of the truck for the summer months.
Yes, it is. It's Meyer EZ-mount classic.
Google around for ez-mount blade and you'll be able to buy some. Some will be complete, some won't. You need the plow frame, pump, and lights.
Meyers E60 Pump, EZ Mount, Nite Saber lights, 7.5 blade this is an example.
Thank you much! How common are these? And so this will only work with EZ mount plows, right?
