Texas Chapter Join Chapter, Leader: LibTimothy
'67 F100 - Relocate the Gas Tank
Old 09-12-2002, 09:11 AM
Crowbar65's Avatar
Crowbar65
Crowbar65 is offline
Old 10-20-2002, 05:34 AM
GolferSA's Avatar
GolferSA
GolferSA is offline
To free up the room behind the seat, I've been considering building (ok, having built) a box in the bed, just large enough to hold the gas tank (standing upright the way it is behind the seat), with a lift up lid to access the filler spout and a locking gas cap for peace of mind. Think of a "between the bed rails" diamond plate toolbox, 8.5" deep by 65" wide by 18" tall, standing upright. Minimal work to re-route the fuel lines and electrical, Plus you get to keep your sending unit, you only lose 8.5" of bed space, and my spare can stay hanging underneath out of the way. I would leave the original filler neck in the cab, and just cap it off inside, to retain the original look of my truck.
Thoughts?
GolferSA
67 Ford F100 Custom Cab
352V8 C6 Auto Factory Air
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5688&.jpg
golfersa@netscape.net
Check out my gallery!
Old 10-21-2002, 01:08 PM
Rosati's Avatar
Rosati
Rosati is offline
You may find that your tank will get water inside from condensation. If the tank is cool and the sun comes out, it will warm the outside of the tank causing condensation on the inside. If it was under the truck, your bed would block the sun. Also, how are you going to mount it? Be sure to isolate it from metal to metal contact. Hope I helped.
Old 10-21-2002, 06:18 PM
GolferSA's Avatar
GolferSA
GolferSA is offline
Ken...
Not trying to be a smart*ss, but help me out.
Inside the cab in the hot sun, or inside the box in the hot sun... inside the cab it's attached directly to the metal back wall, inside the box it would be attached to the back metal wall. What's the difference?
FYI I was going to use whatever mounts are inside the cab inside the box, so it would be mounted the same way... anticipated needing some rubber bumpers to insulate the tank... appreciate any feedback.
Thanks!
GolferSA
Old 10-22-2002, 09:24 AM
Rosati's Avatar
Rosati
Rosati is offline
No offense taken or implied. Just trying to help consider all of the angles. The metal to metal contact I was refering to relates more to exposure and rust than anything, the tank doesn't get wet in the cab.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: '67 F100 - Relocate the Gas Tank
