99 f350 no brake lights, please help?????
i checked all fuses and they're all fine,
can you guys help with the location of the brake fuse and brake relay if any,
i notice two days ago that the right side turned on very weak and latter it was fine i attache a trailer i just bought, i went around the block to test the new trailer brakes i just installed and when i came back i had no brake lights track or trailer, but i still have turn signals and emergency lights, I checked the brake pedal switch and i found power coming out when i depress the pedal but nothing goes to the brake lights
thanks in advance you guys are so kind just by taking your time to read other people's problems.
I had the same issue a couple of weeks ago. The brake lights were out, but the third light on the cab was working. Turn signals worked fine, but the hazards were erratic. I could not locate a fuse at all, nor does the factory service manual indicate a location. I removed the turn signal switch from the column, and ran the point to point circuit test on it, but found nothing wrong. I put it back in, plugged the harness back in, then everything worked again normally, and has ever since.
shargue
Electrical Systems/Wiring
08-13-2017 07:38 PM
wagontrader
02-14-2011 02:24 PM
southbound35west
11-30-2009 08:36 PM
