97 PSD 350 city owned mechanics utility vehicle should I buy?
Old 11-04-2009, 11:41 AM
cyclone429's Avatar
cyclone429
cyclone429 is offline
4wd Low
first off I have never owned a diesel, checked out powerstrokediesel's youtube vids But but but, stil not sure. Here's the info if some one could offer some advice.
reg cab with a utility box on along both sides are the compartments liike pic below. air compressor under the hood along with hose reel inside one compartment. 44,738 miles on it. couple of holes in drvrs side floor pan. Drw very plain interior had been siting for 1 to 1.5yrs now. old guy is getting out of used car business sons not interested. body lines straight but with a city own vehicle I am going to guess and say the mechanics used this truck for city owned equipment break downs on the road, why else would they have a compressor on board. similar to pic below though not it. Oh the price- 1750.00 cash. But I only looked last sunday never heard it run or start. only 2wd & I would have to discard the utility for a 8' box.
<a href="http://s205.photobucket.com/albums/bb118/moldy20/?action=view&current=utilitytruck.jpg" target="_blank"><img src="http://i205.photobucket.com/albums/bb118/moldy20/utilitytruck.jpg" border="0" alt="utility truck"></a>
Old 11-04-2009, 11:43 AM
cyclone429's Avatar
cyclone429
4wd Low
That is one thousand seven fifty canadian dollars.
regards Moldy
Old 11-04-2009, 01:31 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
The pictured truck is not the 97, good. I was gonna say, that ain't no 97! I own one. That's a real good price for a psd. Only 44,000 miles is awesome! I would change ALL the fluids and filters, and especially use some injector cleaner in the first few tanks. Keep a spare fuel filter with you, and a spare cps (cam positioning sensor).
These trucks don't have a lot of giddy up with factory tuning, but some modifications can due wonders to these engines. Your truck will likely have a lower geared rearend than an F-350 would normally have since it left the factory as a cab and chasis. That will hurt your mileage a little, but if you plan to do a lot of towing, that would be a big plus. BTW, I don't know if an 8' bed will bolt on to your truck without tire or axle interference. The rear axle on a cab and chasis is shorter than an axle out of an F-350 dually.
Old 11-04-2009, 08:36 PM
BlueMule's Avatar
BlueMule
BlueMule is offline
For that price I'd go get it right away, and when you get it come on down and see me and I'll trade you a rust free 8' box from an Az truck for your utility box.
Old 11-04-2009, 09:16 PM
CampSpringsJohn
You might need to swap axles too. I'm pretty sure that a cab and chasis dually has a shorter axle than a regular dually pickup.
Old 11-04-2009, 10:34 PM
BlueMule's Avatar
BlueMule
BlueMule is offline
You're right, a cab/chassis does have a narrower frame and shorter axle tubes. But if it has an 8' box it's just a DRW F350 and not a cab/chassis
Old 11-04-2009, 11:02 PM
ford pride's Avatar
ford pride
ford pride is offline
i got two 97 psd and you take care of them andthey will run forever ihave one with286.000 and the other with 168.000 i wouldn't think twice about buying as long the eng. is on the up an up
Old 11-05-2009, 06:43 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
Cab/chassis wheel base is 3" longer, too, so you'd have to set the stock bed back further.
Odds are if it's a dually with a utility bed, then it's a reg. F-350 p'up, as the cab/chassis look rediculous with a utility bed and the narrower axle.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
