How Do I Polish A 1966 Grille ?
Steel or aluminum? Right now it's best and probably cheaper to take it to a chrome & polishing shop. Most shops are hurting by the economy and will do a good job cheap. you might need to shop around a little but it's worth it. 1 1/2 years ago it would've cost you $200.00- $300.00 but now you can probably get it done for $100.00 or less. Most shops need the business no matter how small it is.
Original Alum. grills are anodized. You first have to remove that before any polishing can be done. There are several methods available. I suggest that you Google it and find what you think works best for you.
John
John
Purchased a small container of anodize remover. Then worked out dents and straightened the grille as best I could, need to use caution the alum. is very soft. I then used medium sandpaper, keep in mind the scratches eventually have to be sanded out don't want to start out too rough. Started with 320 grit and progressed to 1500-2000 grit paper. The higher the grit the greater the gloss. Went with the dull sheen, did not go for the high gloss. I assume if use alum polish the residue will need to be washed off for the clear coat to adhere. Grille is made of low grade alum alloy and requires a clear coat to preserve the finish. I used an aerosol can of clear and the label indicated designed to preserve alum. Eastwood carries a product claims to preserve alum for extended period of time. If there's a clear powder coating I may consider checking into it if not too expensive, may preserve the alum longer. Finally, a do it yourselfer is labor intensive and there may be occasion where question what u got yourself into. May want to inquire into cost of having anodized. Also, told by plater it's not recommended to chrome alum, too soft and within short period of time where flaws from rocks and other road debre would be more pronounce, plater suggested if going to chrome go with the metal grille.
Hey Dave,
How many hours do you think you had on that grill? What condition was it in when you started? Were there any major dents?
664x4drvr, If asking how to polish a grill, I take it not much metal working background. Read Dave's post carefully. There is a lot of work to getting a grill to look polished.
John, thanks!!!
Robert: salvaged from a construction truck, the grille was in poor shape, not that many dents but rough and pitted, as if it had been in a sand storm or two. It needed minor straightening, fortunately have a metal grille to use as a templet, regret not taking pic's. Conservative estimate would be at least 16 hrs labor, tend to avoided keeping track as not to get too discouraged. Considered using my 2 1/2 hp buffer but after launching couple trim pieces decided otherwise at the risk of damaging the grille. Again, the 'do it myselfer' is about 4-5 yrs old and time to do it again. Obviously, won't require as much time to redo but still not overly excited. Seem to recall taking pic's at beginning of this summer, from distance may not look too bad but don't want to get too close.
ANODIZE REMOVER
In restoring passenger vehicle took parts to budget chrome shop and ended up taking items to another plater withing couple years. There's Superior Plating out of San Jose, Ca., has reputation for quality work. They straightened and chromed bumpers for my 64 passenger car and did good job. They are expensive. Faiths Plating out of Santa Clara also has good rep but also expensive. Suggest shop around for local reputable plater, for few more quotes, IMO, the est. you got was way to high, had 64 bumpers straightened and chromed for lot less than that. I would not chrome alum grille unless intend to show, and not for a daily driver. Anyhow, had an urge to chime in.
FWIW- I have a aluminum grill on my 66 F-100 and i polished it using hand cleaner and a kitchen scrubby ( the one with foam on one side and green scrubby on the other.) about 4 hrs. because of all the angles in the grill. still shining two years later. it did not remove the gravel pits in the aluminum but worked well for shining. Dave, nice color on the truck. mine is brown also. kinda parcial to that color. Dutch
Dutch, yes kinda like the brown, don't see too many. In its previous life it was a bown Pacific Gas & Electric truck purchased at County auction in 70. Drove the truck for some 35 plus years before deciding to try a 'do it myself' paint job.. Got attached to the truck over the years and wanted to keep it as I found it; although, did lighten the color lil bit, wife refers to it as her pumpkin on wheels, I don't see it.
i used a small amount of stuff called brasso and a little elbow grease and it took the rust off of some cromed steel head light eye brows and the grille shined right up and still looks good and i polished it back in may dont think i have any pics of it on my gallery will try to get some this week
