Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 01:00 AM
jimbeam87 jimbeam87 is offline
jimbeam87 is starting off with a positive reputation.
Four Wheel drive not working
Last weekend I used my four wheel drive on my truck while getting some fire wood. The next morning when I started down the road I noticed that the four wheel drive was was still locked in, but the switch was on two wheel drive. I finally got it to pop out, and thought that maybe it was just frozen from where it was cold out. Yesterday I had to use it again so I locked the hubs in and started up that hill that required its use. I quickley noticed that the front wheels weren't turning, but the transmission was in four low like I had selected.
I finally made it up the hill, but ran into the some problem with the four drive not wanting to pop out. I finally got it to pop out after I shut the truck off and then restarted it. Later on when I got home I test it again to see how things worked. I made sure the hubs where locked and put the truck in neutral. Then I selected four wheel drive and once it did the same thing.
A few months ago I changed out the factory POS and put Warn Hubs on and it seemed to be working fine. Anyone have a clue??
  #2 (permalink)
Old 11-01-2009, 01:06 AM
redford's Avatar
redford redford is offline
redford has a very good reputation on FTE. redford has a very good reputation on FTE. redford has a very good reputation on FTE. redford has a very good reputation on FTE.
jimbeam87 welcome to FTE!
I'm guessing you have ESOF?
if so, it sounds like the shift motor on the transfer case is becoming problematic. Pull it iff and test it. Maybe a cleaning and an some WD-40 will help, but it probably needs replacing.
__________________
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package 5.4L 3.73 LS Tow Command
Presently working as a military contractor in Afghanistan.
  #3 (permalink)
Old 11-01-2009, 01:09 AM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
Can you simplify it? What do you mean by pop out. Are the wheel hubs working OK? So there is no vacuum because you blocked it off?
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #4 (permalink)
Old 11-01-2009, 01:32 AM
Vacuum??
The transfer case locks into four wheel, but the hubs don't seem to be locking in all the way. I can tell its shift into four wheel drive because got it stuck in four wheel low and it wouldn't pop out.
A friend of mine suggested the shift motor thing, but I don't even know where its at.
Was there something else I was suppse to do when I changed them hubs out. I do remember having a ring or something left over, but I remember there being two sets of rings. They might of lock rings, but I cat really remember.
  #5 (permalink)
Old 11-01-2009, 01:38 AM
redford's Avatar
The stock automatic hubs use vacuum to shift the hubs into FREE and LOCK. When you installed the manual hubs you should have plugged the vacuum lines that ran to the stock automatic hubs.
The shift motor is located on the transfer case. It does the actual shifting from 2H to 4H to 4L. Most neighborhood auto part stores will have a replacement motor in stock if you need one.
__________________
  #6 (permalink)
Old 11-01-2009, 01:45 AM
The only line I remember seeing is the wire for the ABS sensor, but I'll check again. I had the "Locked or Automatic" type of hubs on there and the were dry as a bone.
  #7 (permalink)
Old 11-01-2009, 01:49 AM
redford's Avatar
Yes, the dry hubs were probably why it failed. Most folks don't pay any attention to the hubs until they need them, at which point it is too late. They should be removed, cleaned and given a very light coating of grease every 30k miles or so.
While the vacuum lines should have been plugged, this is not the reason for your truck to have problems shifting into and out of 4H or 4L. The motor on the transfer case has nothing to do with the vacuum at the hubs.
__________________
  #8 (permalink)
Old 11-01-2009, 09:17 AM
Rugby3's Avatar
Rugby3 Rugby3 is offline
Rugby3 is starting off with a positive reputation.
The other thing to remember when shifting into and out of 4 LOW is you need to put it in Neutral and step on the brake pretty hard before moving it out of low. There was a thread about this earlier in the week. It's even covered in your manual.
__________________
01 F-250 XLT CC LB V-10 4x4
True Blue/Silver Metallic
Got HossPower?
  #9 (permalink)
Old 11-01-2009, 10:27 AM
I'll give this a try and see whats happens.
Thanks JDM
  #10 (permalink)
Old 11-01-2009, 12:53 PM
EXv10's Avatar
Quote:
That's probably it. Does your AC work good? What do those rings look like you left out?
__________________
  #11 (permalink)
Old 11-01-2009, 02:18 PM
I haven't tried the AC lately so I can't answer that one. The ring is a retaining ring is remember correctly.
I found the vacum line and stuck a screw in it for the time being to see if that worked. After that I made sure the hubs were locked and turned the drive shaft going to the front in. The axle on the drives side didn't turn, but the one on the passenger side turned. I tried it on the hill behind my house and it would climb it. I took the lock out apart to check things out and it looked fine.
Does the shift motor look like a small starter??
  #12 (permalink)
Old 11-01-2009, 07:56 PM
EXv10's Avatar
Yep small starter. Your AC won't work with any vacuum leaking.
__________________
Tags
4wheel , drive , f150 , f250 , f350 , ford , location , locked , low , motor , pops , problems , switch , truck , wheel , working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
