Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
- Why Can't I Get Into or Out of 4WD?
Guide to diagnose trouble and recommended solutions
Four Wheel drive not working
If you're at Pismo, you want to be down around 10 pounds in that sand. What you're experiencing is rear end hop. You're axle is spinning and jumping because it's digging in and out of the sand.
Take your tires down to 10 pounds and it will stop. You want your tires to balloon out on the bottom when you're in sand, especially that sand. When I used to take my Jeep there I used to run 6 pounds in the tires.
Good Luck!
Good Luck!
davidstjohn1
1983 - 2012 Ranger & B-Series
02-20-2010 09:22 PM
