We need some Heavy Duty Truck Pics!
#722
The N 1000 series trucks came from the factory with a single axle. Only the 850's and 950's had a tandem axle. The N series truck pictured is a 66 or 67 model and never had the 855 Cummings. The 743 CI 220 was the biggest Cummings you could get for those two years. The 855 didn't come along for the N series until 1969.
#723
Are you sure about that? The NHC 250 is 855.http://www.ebay.com/itm/1967-Ford-N-Short-Conventional-Cab-Truck-Brochure-152443-ER8MSP-/350751920140?pt=LH_DefaultDomain_0&hash=item51aa71900c
#724
I need help identifying this 1966 Ford Truck
This looks like a specialized production vehicle for something. I bought it cause I think its unique and will be fun. Not only for me but my 17yr old son has all sorts of "plans".
But I need some help identifying what this was, is . Loods to me like a 1966 ford F-600, heavy axles, 4X4.
1966 Ford 4x4 Truck - #1441A
#725
Are you sure about that? The NHC 250 is 855.1967 Ford N Short Conventional Cab Truck Brochure 152443 ER8MSP | eBay
#726
on
Would ya start a tread on it in the 66 forum? And post the vin so we can see what it left the factory as. I see a lot of potential there.
#727
C700 box converted to a vac truck
Hey Guys,
I am fairly new to this forum and would like to share photos of my truck, but can't seem to figure out how to post pics. I uploaded them to my album, but can't get them in a post.
In the posting rules box in the lower left corner it says I cannot post attachments. How do I change this?
Any help would be appreciated.
Thanks,
Gary
Thanks,
Gary
#728
on
Become a supporter and you can post attachments right away.
Or try one of these options.
Could we see some pictures? Here is how.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
#729
don't know anything about these other than the haul gravel from the quarry in dell rapids, sd.
sorry for the poor pic, but this is the best i was able to do so far.
an educated guess would be north of 300k gross when loaded, because at 200k we only need 13 axles here in SD. if i ever get the chance i'll ask a driver if i ever see one hauling onto a project.
#730
Received 5,160 Likes
on
#732
on
#733
Here's the axle limits for Michigan, if anyone is interested:WasteWatcher-Michigan Weight and Axle Load Limits
#735
1987 F800 Hauler
Here's a few of my 1987 F800 with 60" Stand up sleeper, Road Ranger 10 Speed and hauler bed. Had the 7.8 240 HP motor around 10,000 miles on the motor. Air Ride seats, Air ride rear,24.5 Alcoa Wheels and tires Old truck needs TLC and will get it over the next year. Will replace or rebuild anything that needs work on it. Rewire everything that has been hacked over the years. 300 Gallons of fuel on board
Plans are to use it to run cross country with our 41ff 5th Wheel camper. Truck is not a race truck, but pulls like there's no end in site. Being it was build when even the Interstate speed limits were still 55 MPH it was built for pulling a load. May turn the RT6610 trans into a RTO6610 back to the dash for high gear and Haul Butt.
Need to find info on taking the dash out of one of these, as it will come out and do any wiring or air line issues under there. Wil also be removing the Big fuel tank off the bed also.
Pint after a little work and colorback . Will be painting it later to match our camper.
Will be towing this with it.
