Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 and Newer F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
The 2009 and Newer F150 Discuss the new 2009, 2010 Ford F150 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-26-2009, 10:56 PM
09 Razor's Avatar
09 Razor 09 Razor is offline
09 Razor is starting off with a positive reputation.
2009 Transmission Temperature Guage
I just bought a 2009 F150 with the 5.4l and the max trailer towing package. When I start it up, the trans temperature gauge goes to mid span quickly. In my last truck, a 2000 GMC 2500, the gauge would stay on cold except in hot weather or when towing.
Is it normal for the gauge to indicate the fluid is warm so quickly?
  #2 (permalink)
Old 10-27-2009, 12:59 PM
Motown Fire's Avatar
Motown Fire Motown Fire is offline
Motown Fire is starting off with a positive reputation.
I think the temp sensor is next to the exhaust pipe and gets heat quickly like in the super duties. My trans gauge starts at cool and moves up as I drive. I'm just guessing here, I am sure someone with the correct answer will be here soon.
__________________
2009 F-150 XLT
Crew Cab 4X4
4.6L 3V Auto
  #3 (permalink)
Old 10-27-2009, 02:33 PM
Power Kid Power Kid is offline
Power Kid is starting off with a positive reputation.
The sooner it gets warm, the better your MPG. Ford has done this on purpose for MPG gains.
  #4 (permalink)
Old 10-27-2009, 02:40 PM
04XLTRUNNER's Avatar
04XLTRUNNER 04XLTRUNNER is online now
2009 Ford F-150
04XLTRUNNER is starting off with a positive reputation.
my warms up slowly when im driving, but if i let sit in the driveway and idle it moves a little faster.
__________________
2009 F-150 FX4, Dark Blue Pearl, Supercrew, Sony System, Exhaust, HID's, Shorty Antenna, Optima Red Top, Daystar 2" Level Kit, 35x12.5x20 Mudgrapplers, more coming soon.....
Gone:
2005 F-150 lariat 4x4
2004 F-150 xlt 2x4
  #5 (permalink)
Old 10-27-2009, 05:29 PM
BillBoy BillBoy is offline
BillBoy is starting off with a positive reputation.
Could the trans work like the cooling system. Using fluid in the trans and not the reseviour untill every thing warms up them then a valve like the cooling thermstat opens Then the trans always has warm fluid and not starting out on molassas during the winter. ???
Mine does the same as described by others, and workd fine with the trailer behind.
  #6 (permalink)
Old 10-31-2009, 03:42 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE.
Yes the trans has a thermostat that will re route fluid back to the trans in cold weather. But the temp gauge is fake just like the superduty trucks its just an idiot light. The PCM controls where it moves and it should move right on up to half way in under 2 mins of driving and stay there. Only if the trans gets to 225 degrees will it move to the "hot" mark and by then you have already done a lot of harm to the trans.
__________________
If it doesn't fit, FORCE it.
If it breaks, well, it needed replacing anyway.
  #7 (permalink)
Old 11-01-2009, 12:05 AM
tvsjr tvsjr is offline
tvsjr is gaining momentum as a positive member of FTE.
I'm not sure I agree with that... my trans temp gauge in my '09 will stay cold until I drive it... and it actually seems to vary some. Get in a hilly area with a trailer where it's working the tranny a bit and it will climb a tad. My '05 SD was definitely a gauge version of an idiot light - I'm not sure my 09 is...
  #8 (permalink)
Old 11-01-2009, 12:56 PM
aliasmax aliasmax is offline
aliasmax is starting off with a positive reputation.
Had a problem with my trany temp gauge also. took it back to the dealer and they told me they had to reset the controler. What controler i have no idea. After i picked it up the gauge starts moving after a mile or so and by 5 to 6 miles it's up to a little left of center
__________________
2009 F150 XLT Super Cab 3.55 ls Chrome package Driver package
2004 Chrysler Sebring Convertible
2001 Pontiac Grand Prix GT
  #9 (permalink)
Old 11-01-2009, 04:02 PM
montecarlo31 montecarlo31 is offline
montecarlo31 is starting off with a positive reputation.
Quote:
That's true. There was a reflash for 09 model trucks due to customer concerns over their trucks Trans Temp gauge not functioning proper.
  #10 (permalink)
Old 11-02-2009, 12:00 PM
2009 Ford F-150
mine seems to work like it should, it changes depending on the weather and if i have a load. its not just an idiot like. mines an actual working gauge
__________________
Gone:
2004 F-150 xlt 2x4
  #11 (permalink)
Old 11-03-2009, 10:37 PM
09 Razor's Avatar
Transmission temperature gauge
Thanks for the replies. It is good to know that others have noticed the same thing as I did.
I became concerned with the gauge's accuracy when I noticed that if I started the truck from cold condition (about 35 F) and left it in park, the transmission temperature gauge would indicate about 1/4 of the way up after just a few minutes. In this case, the indicated transmission temperature increased far quicker than the engine temperature.
I brought the truck to the dealer to have them check into it. They reprogrammed the TCM and PCM, installing the latest software into each but they reported that there were no other issues. No codes set or complaints logged in OASIS.
If this is normal, I guess I'll have to get used to it but I worry what will happen when I tow in 90 - 100 F temperatures?
  #12 (permalink)
Old 11-05-2009, 12:46 PM
2009 Ford F-150
i towed a 20 something foot trailer with a tractor over the summer when it was 102 outside and didnt have any problem. and it was a pretty heavy load.
so dont worry, these trucks are made to pull. that way the the radiator and trans cooler are upgraded.
__________________
Gone:
2004 F-150 xlt 2x4
  #13 (permalink)
Old 11-06-2009, 01:14 PM
berry1234's Avatar
berry1234 berry1234 is online now
berry1234 is starting off with a positive reputation.
You might be able to see the actual temperture via the 'engineer' mode. This is for an Expedition, but may work on the F150.
Engineering Test Mode:
Ignition in "OFF" position.
Cluster type.
For Base Clusters (without message center cluster): depress the reset stem on the cluster while turning the ignition switch to the "ON" position.
Message Center Clusters: depress the reset button in the vehicle while turning the ignition switch to the "ON" position.
Continue to hold down the reset stem/button for 5 seconds until the cluster message center displays "engineering test mode".
Press/cycle reset stem/button until the message center displays "manufacture" and the date of manufacture (MM-DD-YYYY).
Keep cycling through to get to mpg/KM, coolant temp, etc.
__________________
2008 Expedition Eddie Bauer 4x2
1978 F250 Lariat 4x2
  #14 (permalink)
Old 11-06-2009, 02:02 PM
2009 Ford F-150
it worked on my 05, it should work on the 09s. i love the digital speedo in the list.
__________________
Gone:
2004 F-150 xlt 2x4
Tags
2006 , f150 , fake , ford , gauge , grand , guage , heat , idiot , install , moving , normal , prix , temp , temperature , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
