Safety allert about brake cleaner and welding
This guy used brake cleaner on an area before welding and almost died. I dont think this story is a hoax. Be careful!
Brake Cleaner = Phosgene Article
Definitely no joke. I had an experience similar to 'fenders. I built a new engine for my Falcon early last spring and used chlorinated brake parts cleaner to clean the block before final assembly. I was running a kerosene torpedo heater and after awhile the chlorine fumes were getting pretty strong. I was almost done for the night, so I pushed on a little longer before I quit. Hey, I never said I was very smart! I had a splitting headache for two days afterwards and everything in the shop that was bare metal had rusted. I won't even touch a can of the stuff anymore. Go for the non-chlorinated.
It was the combination of argon shield gas, used in mig and tig welding, the heat produced and the brake cleaner that can produce phosgene gas. There are times when I need to degrease something before welding. If I used the brake cleaner I have on the shelf to clean the part and some is left in a crack it could be vaporized from the welding heat, mix with the argon shield gas and bingo! One snort of that could ruin the rest of your life. Im glad I did not learn that the hard way. Also, I believe running freon through an engine sends mustard gas out the tail pipe.
Phosgene Gas...
...anyone with ANY approved training, schooling, and certifications in any
form of HVAC with an EPA Approved Universal Technician Certification
Card compliant with 40 CFR 8.2 Subpart F. SHOULD be able to tell you
that simply by heating galvinized sheetmetal with an open flame for only
a few moments is long enough to PRODUCE PHOSGENE GAS due to
the Zinc content in the galvinized coating.
I have seen this happen...
...we had to clear the entire area immediately and discard all the
effected clothing BEFORE it was brought in to anyones HOME!
THIS IS MUSTARD GAS!!!
REMEMBER WWI???
Welding is NOTHING to taken light heartedly...just because Home Depot
sells welders next to snow shovels does not mean it is simple...
REMEMBER WWI???
I bet a lot of people here don't realize interior spray glue is almost as wicked. I sure didn't know refrigerant was deadly. Thanks for the heads up. I guess I'll stop sniffing it from now on.
John
NNY
