Cranks but doesn't start.
91 F-150 XLT lariat package, 302, about 130,000 KM on it. Engine has a rough idle (when warm) and lacks oil pressure at idle, again when warm. This has to do with the bearings, and am not worried about that. Recently swapped out alternator after the last one caught fire. Replaced plugs, wires and rotors about 1500 KM ago.
Was backing out of the driveway on my way to school, went over the curb, and the truck just died. Pushed it back into the driveway and then swore a whole bunch and went inside. Delved into the Haynes, not the inertia switch, nor the fuel filter(replaced). Fuel pump primes. The following stats I have taken earlier today.
Compression test: 60 PSI on number 1 cylinder
Fuel pressure test: 40 PSI to fuel rails
Fuel Injectors are getting pulses (inline test from injector lead to + terminal battery)
Distributor Cap rotor does turn when cranking engine, leading me to believe that the timing chain is still functioning. Looked for the cam through the oil cap, piece of steel that blocks view.
Spark is hitting cylinder head. Verified during compression test, as well as the inline tester that I bought and checked on each cylinder.
So what else could I be missing here? Has nothing to do with spark, ruled that out. Timing doesn't have anythign to do with it either, have rotated the distributor while cranking the engine and haven't gotten anything. MAP? TPS? I am at a loss, and kind of want to push the damned thing into a lake, after lighting it on fire.
600 KPA/6 bar/75-80 psi. I couldn't find what it should be running at anywhere in the Haynes. Head gasket? Would it cause a no start? For the timing I guess I would have to take off the timing cover and all that...Is there any sign I should be looking for?
I have been working on an 87 Ranger with a 2.3. When I got it it had a miss. Did a compression check and three cylinders had 110-130psi and one had 80psi. That was where the miss was coming from. Rebuilt it and it runs good with no miss now.
Steve
