Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-23-2009, 11:42 AM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is offline
MoyockPowerstroke is gaining momentum as a positive member of FTE.
Rear Diff Pinion Seal Replaced...No more leaking
Well the pinion seal has been replaced. Decided to do it myself rather than pay $165 (parts & labor)…mainly because my brother was on hot standby 800 miles away and I could call him the moment a problem would arise. Only had to call him a couple of times. The Pinion shaft nut took a 1 1/8” socket. I had to use a propane torch to heat up the four 12pt 12mm Driveshaft support bolts before I could back them out. I used the count the turns of the nut method after marking the pinion shaft and yoke and socket and …you get the ideal…The main headache I had was the Yoke companion flange…it did not want to come off easily…so I had to employ a gear puller…still with the puller and tap as I went along, it took approx 45 minutes to finally get it off (my brother thought this was peculiar). Old seal came out; new seal went in (textbook). Put the Yoke back on and tightened her back with the same amount of turns that came off…plus a scoatch….torqued down the driveshaft bolts, topped off the pumpkin and scrubbed the under carriage to clean off the splattered gear lube. No leaks.
__________________
Real Trucks Don't have Spark-Plugs '05 6.0L, Lariat 4x4, 83k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto, Coolant bypass, ZooDad, HighIdleMod, BullyDog 4" TB 4"DP (BullyDog ate Kitty), SCT SF3 Perf Strat, 24" Wipers, '08 Rear Diff Cover, Upfitters, Skyjacker/Russell brakes lines, M/C Max 100 BXT-65-850s, Mobil1 Syn 5W-40, Wagner ThermoQuiet's, Stanadyne Perf Add & FPPF Lubricity+Power Add., Prodigy Brake Controller, Nitrogen filled Bridgestone Dueller A/T Revo's, Satellite radio, Sun-visor.
  #2 (permalink)
Old 10-23-2009, 12:06 PM
iron1951 iron1951 is offline
iron1951 is starting off with a positive reputation.
Thanks for the scoup on how this was done. I was wondering. If mine leaks I will do it at home now.
  #3 (permalink)
Old 10-23-2009, 12:26 PM
senix's Avatar
senix senix is offline
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
That is the way to do it...now just monitor.
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #4 (permalink)
Old 10-23-2009, 01:35 PM
iron1951...just as a sidenote...by scoatch I mean 1/16th of inch. Once you pick up the new seal...compare it with the old one still seated, so you know what parts come out and what stay. That way you know where to get a needle punch under the lip of the metal outer ring...once I got that bent out a little I grabbed it with visegrips and hammered the visegrips shaft to pull the seal out (this is right out of the manual). Putting the new one back in (after lightly greasing the outer metal race and inner rubber ring of the new seal) was accomplished by holding in place with the left hand using a block of 1"x2" wood and tapping in with the right hand...or reverse if you're a southpaw. Make sure it seats fully and you're good to go.
__________________
  #5 (permalink)
Old 10-23-2009, 03:15 PM
AlaskaJeff's Avatar
AlaskaJeff AlaskaJeff is offline
AlaskaJeff is starting off with a positive reputation.
Nice write-up, my pinion seal is seeping a bit and I will be doing this SOON!! Thanks
__________________
Jeff Reichel
03 F250 V10 King Ranch Crewcab, Mildly Modded Daily Driver
Palmer, ALASKA
CHRIST for LIFE!
Phil 4:8
  #6 (permalink)
Old 10-23-2009, 03:27 PM
senix's Avatar
be sure to mark your driveshaft location before remove. that is about the only thing I think he did not mention.
__________________
  #7 (permalink)
Old 10-23-2009, 03:30 PM
senix...thanks for pointing that out...I did use a paint pen and marked the driveshaft orientation to the yoke companion flange...I even went as far as individually marking each of the four 12mm/12pt bolts with paint dots 1,2,3, and 4 to ensure they went back in the exact bolt holes they came from. Kinda anal, but I didn't want any problems later on.
__________________
  #8 (permalink)
Old 10-23-2009, 07:26 PM
nitrogen's Avatar
nitrogen nitrogen is offline
nitrogen is gaining momentum as a positive member of FTE.
it good to be aware of driveshaft orientation, but the only time it is of concern is if you pull a slipjoint apart. the issue is when 2 adjacent ujoints are not in phase. what i mean is that if you take a driveshaft with 2 yokes they must both have the crosses the same.if the front cross is facing 12 and 6, the rear one must be the same. it is possible to be off by 180 degrees so its good to use a paint marker or punch to mark the join at the slip joint. 180 is not horrible but it throws out the balance job, sometimes it'll vibrate sometimes its ok
__________________
2005 F350 Lariat crew 4x4
traded F350 XLT supercab 4x4 what a stinker
  #9 (permalink)
Old 10-23-2009, 08:12 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
The slip joints in SuperDutys have one spline that's twice as wide as all the others, effectively "keying" the two pieces, and preventing you from mating them in any other way than how they're supposed to be.
You're only going to get it back together one way. The correct way.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #10 (permalink)
Old 10-23-2009, 08:32 PM
jayford jayford is offline
jayford is starting off with a positive reputation.
i have changed the pinion seal in my f250 also,but am running into problems replacing the pinion flange. it will start a lil but thats all. i bought a new flange from ford and no luck.
  #11 (permalink)
Old 10-23-2009, 08:50 PM
jayford. Once I placed the yoke flange back on the pinion shaft splines I had to tap (not too hard) it until I had a couple of rows of exposed thread IOT get the pinion nut started. Once I got the nut started I just worked it around counting back the same amount of turns it took coming off....it will actually walk the yoke companion flange back onto the pinion shaft and tighten up like its supposed to. Good luck.
__________________
  #12 (permalink)
Old 10-23-2009, 10:20 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
I have fixed hundreds of rear ends and counting the threads to get the nut back into place is a bad idea. You are not accounting for any wear of the pinion bearings and the possibility that the nut has backed off. Chances are the seal was bad in the first place because the pinion was loose. Thats like putting your boot laces back to the same tightness after going half way through a hike. Tighten the nut down until there is a slight drag on the yoke (like it is supposed to be). Go slow here so you don't have to back the nut off to attain the drag. Not only have you not accomplished anything but now the nut is loose and prone to backing out. Use a seizing compound also.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #13 (permalink)
Old 10-25-2009, 01:44 AM
EXv10...you're one of those rolling torque guys huh? So what you're saying (which differs from very many both on this forum and other sources) is that everyone should just go to the dealer to get the repair done....wrong answer. DIY....they do it EXACTLY as I described...I checked two local dealerships and 2 independent mechanics ....Why pay +$165, when the part cost $17. Jayford ...DIY, don't listen to EXv10...unless he's willing to share by breaking down his method for you in detail on this forum. lol
__________________
  #14 (permalink)
Old 10-25-2009, 02:47 AM
EXv10's Avatar
Who said anything about going to a dealer? Your post makes 0 sense to me?????????????What rolling torque????????? What part costs $17? Are you a mechanic?...........Your truck is pretty cool with that locking gas cap LOL
__________________
  #15 (permalink)
Old 10-25-2009, 10:33 AM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
Easy guys !
i've done them both ways (rolling torgue or nut torque).
But in a pinch done his way also.
Being a retired ford tech ,you find ways to beat the slt times given by ford to make money.
Never had a comeback on either way.
A key thing to remember about pinon seals is if the seal runs dry an scores a groove in the seal surface ,it will leak again in a very short time.
If you reused the same pinon nut you had better chk on its tighness down the road .
They are not to be reused. they are like a nylock nut.one time only
If you need or want the written way for proper rolling torque or nut torque ,I will explain it .
Rich
__________________
" All levers like real trucks should be!" "Cool enough for me!"
" BSEG CLUB" 10 Strokin and 4 Smokin!
Tags
150 , 2002 , additive , f150 , f250 , ford , heavy , leak , leakingf250 , leaky , pinion , psd , rear , remove , replace , seal , seals , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
