Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Arizona Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Arizona Chapter Join Chapter, Leader: Bill W
  #1 (permalink)
Old 03-29-2002, 07:31 PM
460lover 460lover is offline
Garage is empty, add now
460lover is starting off with a positive reputation.
Sealant for oil leak on timing cover
Is there any type of sealant(spray or otherwise) that I could use to help with an oil leak on the timing cover on a 460. I can't afford (time mostly) to replaced the seal at this time.
__________________
Jesus Christ is Lord, King and Savior
  #2 (permalink)
Old 04-02-2002, 05:03 PM
Water Dog Water Dog is offline
Water Dog is starting off with a positive reputation.
If you can get to the timing cover, you can clean around it very well with MEK, must be oil free, and then smear on some silicone sealer with your hand.I recommend that you ware disposable rubber gloves.I have done this in the past and it is only a temparay fix.If it is leaing around the crank shaft you are out of luck.:
FORDS WILL STILL BE RUNNING WHEN ALL THE GENERAL MOTORS JUNK IS ON THE SCRAP HEAP!
  #3 (permalink)
Old 05-26-2002, 10:53 AM
HEFTY F350 HEFTY F350 is offline
HEFTY F350 is starting off with a positive reputation.
Something else to keep in mind. If you have an oil leak that just wont quit. There may be another cause. The crank case builds pressure. If this pressure is not vented (pcv valve), you will have oil coming out of the weakest sealing area. If your engine has a few miles on it, this is most likely to be the valve covers, front seal or rear main seal. They all have an abundance of oil being splashed on them constantly.
A troubleshooting aid is to take a piece of paper about the size of a dollar bill. Remove the oil filler cap and lay the paper over the opening. Watch to see if the paper is being blown up or being sucked down. If it is being sucked down, your pvc system is working the best it can. If it is being blown up, check the valve for vacuum and flow.
A pcv valve can only flow so much. Good luck.
  #4 (permalink)
Old 05-26-2002, 11:24 AM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
Founder ... Stay Tuned
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
__________________
The best is yet to come....
Tags
351, cleveland, cover, diesel, engine, ford, housing, leak, leaks, oil, repair, sealant, sealers, silicone, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
