Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-15-2009, 10:48 PM
hunts55 hunts55 is offline
hunts55 is starting off with a positive reputation.
55 f 100
i have a 55 f 100 with a 6 cyl. it has new points and dist cap , just had the carb rebuilt runs good but just will not idle i tryed adjusting the fuel mix screw and it made no difference. any one have any ideas ? thanks
  #2 (permalink)
Old 10-15-2009, 10:52 PM
Julies Cool F1's Avatar
Julies Cool F1 Julies Cool F1 is online now
Posting Princess
1951 Ford F-100
Julies Cool F1 has a good reputation on FTE. Julies Cool F1 has a good reputation on FTE. Julies Cool F1 has a good reputation on FTE.
Hi and Welcome to FTE.
I know this is going to sound stupid and I don't mean to be derogitory to a newbie, but did you try and adjust the mechanical idle set screw? It holds the throttle plate open at the correct idle RPM. It will be under the carb linkage on the side and will usually be a slotted heavy screw with a spring on it.
__________________
Best wishes
Julie!
  #3 (permalink)
Old 10-20-2009, 02:03 AM
t900enforcer t900enforcer is offline
t900enforcer is starting off with a positive reputation.
Did you check for a vacuum leak. A vacuum leak will not allow an engine to idle properly.
T900
  #4 (permalink)
Old 10-20-2009, 09:12 PM
homade's Avatar
homade homade is offline
homade is starting off with a positive reputation.
Take a spray bottle and put a little dawn or ivory liquid in it and spray around the base of the carb and on any vacuum connections, helps to find the leaks, Garry
  #5 (permalink)
Old 10-28-2009, 12:40 PM
thanks i will try that . gary
  #6 (permalink)
Old 10-30-2009, 10:35 PM
rdemilt's Avatar
rdemilt rdemilt is offline
rdemilt is starting off with a positive reputation.
everyone gave you great ideas so far, if none of those help check the timing and then the valve lash. give us more to work with. has the truck been sitting for years ? was it running well and driving before changing out the distributor parts ?
Rick
  #7 (permalink)
Old 10-31-2009, 10:50 PM
I want to thank everyone for all your ideas and your help. I will check all the things you have mentioned. At the moment we are suffering from a minor set back that is holding up the other issues. Right now the wiring is fried! Have to replace the wiring harness due to SMOKE bellowing from the dash! I'm sure some of you can relate to that. Thanks again. Gary and Paula Hunts55
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
