Turn signal relay location??
I just replaced my turn signal bulbs with LED replacements and when I actuvate my turn signal it blinks very fast.
I think if I upgrade my turn signal relay to a heavy duty or electronic it should do the trick and slow things down.
I looked in my manual and could not find the location. Has anyone replaced their relay/ And if so where is it located? Or any pics would be great.
Thanks
JD
Thanks
JD
The blink speed is a common problem when going to LED bulbs - it's due to different resistor values of the bulbs. I had looked into doing this on a different car and bookmarked this site: Tail light and Turn Signal LED Bulbs Fix
Looks like a good solution if it works... love this text from the auction:
Load resistors are a fire hazards, because they get VERY HOT.
It is like installing a Toaster to solve a simple flash problem…..
It's not like these resistors have a load going through them at all times so heat doesn't really get a chance to build up - unless you left your hazards on - maybe that would build up a bit.
If I have to install an inline resistor I will....but for now I'd like to find a simple push in relay/flasher.
I found this place:
LED Flashers Blinkers Resistors Load Equalizers for Turn Signal Replacement Bulbs Rapid Flashing Fix
I found this place:
flasher location
Thanks
JD
Thanks
JD
your flasher relay is easy to find. if look at the bottom of the dash below the radio, you will notice that the panel comes apart. it has four screws this panel is part of your cup holder and ash tray .once thats down and out of your way, look in the dash and its right in front of you. in side of a black box. remove black cover by prying it open its the blue relay in side.
I need to replace mine. Does anyone have a photo of where this is??
