Voltage regulator, battery drain
1987 F250 Diesel, I have a battery drain. I disconnected negative terminal and used test light while pulling fuses one by one (doors closed no dome light), the light stayed on(bright). I unhooked the alternator and the light stayed on. I unhooked the voltage regulator and the light went off. Does anybody think I have found my problem or is there something else I should be doing?
Thanks
Thanks
One other thing you should check is the voltage between each cell of your battery. Pop off the vent caps and stick the probes into the water of each adjacent pair of cells (i.e., 1-2, 2-3, 3-4, etc.). You should get a reading of about 2.1V between each pair. If you have a pair that reads 0, you have an internal short and the battery is bad.
Jason
You can also use a test light, works the same was, when its dim the draw is low, when its bright the draw is high. Well on ur alt isnt the reg but into the alternator? Just get a new alt and plud it in, no need to swap it it. If ur light is still bright then there is another prob, is the light goes dim with the new alt plugged in then you know ur alt is messed up.
Battery drain
I have a 1988 Ford F-250 7.3 diesel and have a battery drain problem let's say today it turns on and drive it all day long and get home and park it and the following day the batteries are dead
I took it to get a check on the battery's and the altenerator and both are good the altenerator puts out the 12 volts
I'm not sure if the if the battery's should be a problem because they both are around 700 cranking amps
By the way the problem gets worse when it's cold
This one is seven years old...
12V is not enough. You should see something over 14V with the engine running.
Have you tried using a test light or ammeter to trace the draw?
Do you have a separate regulator mounted on the fender?
Does the back of the alternator feel warm after the truck has been parked for an hour or two?
saauvenshine
04-01-2016 01:50 PM
F250Rob
20
02-18-2016 08:05 PM
