Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-09-2009, 04:45 PM
CaliBLACK CaliBLACK is offline
CaliBLACK is starting off with a positive reputation.
2005 F150 Window Regulater???? HELP?!!?!?
Need help! i was driving home and i heard a loud bang, next thing i noticed was the window fell all the way down and wont come back up. I hear a slight clicking sound when i press the window button, but nothing happens...maybe a broken regulater???? how much do these cost? can i fix it on my own?
  #2 (permalink)
Old 10-10-2009, 04:29 AM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
2005 Ford F-150
FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all
Sounds like a cable came off "track" and or broke. As along it didn't break the window, it hasn't been an issue for most to dig into.
I assume this was the front passenger side window? If so, its a cinch to remove. Just advise, and we can help (if you need it).
__________________
-Rich
Chapters / 2004-2010 F150 / 2011 F100 Moderator
****Join the South Carolina Chapter here!!!***
..Or your own state chapter Here
  #3 (permalink)
Old 10-10-2009, 12:45 PM
Thanks!
Well i had someone look at it and they told me i would have to buy a whole regulater, which came up to about 187$, 220$ with labor. Does this sound about right? Would it be cheaper to do it myself?
  #4 (permalink)
Old 10-10-2009, 01:22 PM
2005 Ford F-150
I know our site sponsors have the regulator for about 100-112$, but that's not including s&h (?). You might be able to shop around locally, the 187$ seems like its full MSRP.
It more than certainly would be worth doing it yourself.
__________________
-Rich
  #5 (permalink)
Old 10-10-2009, 05:40 PM
lakeforkfisherman's Avatar
lakeforkfisherman lakeforkfisherman is offline
lakeforkfisherman is starting off with a positive reputation.
Welcome to the "Ford Window Regulators Suck" Club. I have had 3 replaced on my 2004 Screw. From what I understand, its a plastic piece on the regulator that breaks. Have to replace the whole thing. Good luck.
  #6 (permalink)
Old 10-15-2009, 03:07 PM
MyViewGS's Avatar
MyViewGS MyViewGS is offline
MyViewGS is starting off with a positive reputation.
Hey, new here. Not trying to hijack the thread but have similar issue. My brothers '05 Screw dropped all four window within a month and became pretty costly to repair. My '07 Expd driver door window just suddenly began dragging. I got it closed and have left it. Noew I hear "rattle" when I close the door. Im pretty sure a pulley has broken and possibly dropped a cable. Id like to correct this before the window drops causing more damage. If someone could give me a link to a "how to" thread Id greatly appreciate it.
Oh yeah !!!! Very nice site and glad you're here !
MyViewGS
  #7 (permalink)
Old 10-16-2009, 01:40 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
I have actually done this job on son's F150.
I would category it as 3 on 1 to 5 scale of difficulty. It took total of 1 1/2 hr to replace the entire regulator (you don't want to try to repair it).
The regulator was bought from Ed. PM me your email and I will send you the procedure I used.
You can do this total job at home for about $135.00 vs the $400 + for professional installation.
One tip.. I found it easier to install the new regulator with 1 person HOLDING the window up to allow the regulator to clear. With the window installed in the regulator I ran the window down and snugged the bottom 2 10 mm bolts then ran it up and snugged the top 10 mm bolts. This assured the window was properly centered. Once this was confirmed I tightened the bolts.
It is easy to scratch the glass and tint but if you use someone to hold it up you don't have to remove the glass from the door and the chance of a scratch is very minimal.
vettdvr
  #8 (permalink)
Old 10-20-2009, 02:44 PM
marsicob marsicob is offline
marsicob is starting off with a positive reputation.
hey vettedvr - would you be interested in posting your procedure right here in the thread? I am not very adept at using this forum and can't find PM's, or I woud send you one like u suggested to a previous poster. I have an 05 xlt that just today the driver side window stopped working and would find some help on doing it myself invaluable. Thanks in advance if you can.
  #9 (permalink)
Old 10-21-2009, 01:52 AM
Andrew4.6 Andrew4.6 is offline
Andrew4.6 is starting off with a positive reputation.
what the hell?!? dang man i feel for u because i swear the same thing happened to me today im going to the shop tomorrow i hope my warranty covers it
  #10 (permalink)
Old 10-23-2009, 04:49 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony has a good reputation on FTE. 1ATony has a good reputation on FTE.
We carry alot of window regulators,but I do not have one for this application.
__________________
Tony
1A Auto Parts
1-866-403-3393
Click Here To Check Out Our Ford Truck Parts
  #11 (permalink)
Old 10-23-2009, 07:16 PM
vettdvr's Avatar
Quote:
Consider stocking them as this will be a common failure.
  #12 (permalink)
Old 11-03-2009, 02:35 PM
Mr Stacy A's Avatar
Mr Stacy A Mr Stacy A is offline
Mr Stacy A is starting off with a positive reputation.
It happened on my 05 FX4 the day after Halloween. I'm taking mine in to the shop this afternoon. I think my extended warranty through Olympicare will cover it with just a $100 deductible. If not, I'll be getting with you guys to find where to order the regulator at the cheapest price.
  #13 (permalink)
Old 11-03-2009, 03:24 PM
vettdvr's Avatar
Quote:
If all you pay is $100 you will be ahead, the part is about $125. Way to go warranty!.
Tip.... prevent damage to these windows by STOPPING just before full up or full down. At motor full speed it is generating full torque. Just tap the button for last 1" up or down to close and reduce stress on the Very TINY braded cable.
  #14 (permalink)
Old 11-04-2009, 04:54 PM
ryan70asu's Avatar
ryan70asu ryan70asu is offline
ryan70asu is starting off with a positive reputation.
Had this happen on my '05 Screw and yes it's a piece of cake to do it yourself. You will kick yourself if you pay to have it done. Dealer was asking almost $500 to do it. Just have to take the door panel off and everything is right there. I used a wood block to hold the window up and out of the way. Took about an hour and a half.
  #15 (permalink)
Old 11-04-2009, 06:07 PM
vettdvr's Avatar
Quote:
Save $$ don't spend the $$ on wood for the block,, use son in law
Tags
05 , 150 , 2004 , 2005 , door , f150 , fell , ford , instulation , motor , regulator , repair , replace , replacement , window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
