Alberta Chapter Join Chapter, Leader: Puddy
Hi
Old 01-12-2003, 09:40 AM
Dave 69_88 F Series's Avatar
Dave 69_88 F Series
Dave 69_88 F Series is offline
Hi
Just noticed this chapter and thought Id say Hi. Iam from the Fraser Valley. Iam curently parting out a 69 F250 and trying to Put the 390 into my 88 F150 4X4.
Bye for now
Dave
Old 01-12-2003, 01:07 PM
sparky's Avatar
sparky
sparky is offline
Hi
Hi Dave;
I am from the Comox Valley. I am currently in the preliminary stages of transplanting a 69 F250 body onto a 73 F250 frame. Right now I am stripping the 73 down to the frame. Too bad you are on the other side of the BC Ferry System as you might have some parts I may need
Neat project you are working on. Just wondering how the 390 is fitting into the 88 frame? A litle fabricating must be involved I mean those engine towers werent made for a 88. I assume you just bolted everything together, engine tranny and mounts. Set it in place where you wanted it to sit. Then just welded/bolted the towers to the frame, adding spacers as necessary. Or is there a better way? Or does it actually fit like factory?
Talk to you later.
Sparky
Old 01-12-2003, 06:07 PM
Dave 69_88 F Series
Hi
Well havent got that far yet trying to find out just what problems Iam going to have. I have a 3 inch body lift in the 88 so that should help. I was hoping that all I had to do was bolt the 69 frame engine mounts onto the 88 frame in the same spot. But it sounds like its more complicated then that. Took me awhile to get some answers to find out how to mate the 390 tranny to my 1345 transfer case just have to change the out put shafts and the adapter. Any advice on what Iam facing would be a big help.
Thanks
Dave
Old 01-12-2003, 07:46 PM
sparky's Avatar
sparky
sparky is offline
Hi
Hopefully they will bolt right on the 88's frame....but I have some doubts the frames changed quite a bit after 79 and the last year of the FE was 76.
But you never know til you try Good luck.
Sparky
Old 01-12-2003, 09:06 PM
Dave 69_88 F Series
Hi
Thanks someone did say that the oil filter will hit in the 88 frame wonder if there is a kit for relocating the filter.
Dave
Old 01-12-2003, 09:24 PM
sparky's Avatar
sparky
sparky is offline
Hi
There should be one around somewhere. They are called remote oil filters, in case you dont know what they are called
Try some of the online sites Wrenchead, jcwhitney just add ".com" I do not know if motorhaven sells them or not.
Sparky
Old 01-13-2003, 12:52 AM
merc460's Avatar
merc460
merc460 is offline
Hi
Yes there is a block adapter for the 390 It will remote mount the oil filter It's made by trans'adapt you can get it at lordco. Eric
Old 01-13-2003, 09:32 AM
Dave 69_88 F Series
Hi
Great thank you.
Old 01-15-2003, 01:47 AM
Dave 69_88 F Series
Flatdeck
British Columbia
31
06-22-2008 03:55 PM
Scott Fraser
07-10-2004 05:05 PM
Dave 69_88 F Series
02-17-2003 01:51 PM
Dave 69_88 F Series
15
01-14-2003 12:06 AM
Quick Reply: Hi
