Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
5-speed in 93 lighning
Old 10-04-2009, 09:58 AM
3-fords's Avatar
3-fords
3-fords is offline
Im selling my mustang and 65 f 100 to buy gen 1 lightning but i want a 5-speed. What would I need to do to make this happen?
Old 10-04-2009, 12:14 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,645 Likes on 1,341 Posts
Bell, clutch, trans, crossmember, possibly driveshaft work, pedals, clutch set up either cable or hydraulic, shifter set up, speedo drive set up.
Ford truck 5 speeds would be a miserable and short-lived choice, so you are looking at a TKO or T56.
TTC: TREMEC Transmissions
Modern Driveline - T5 / TREMEC TKO Transmission Conversion - 5 speed & 6 speed solutions to swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
Rockland Standard Gear Manual Transmissions
No you can't take a T5 out of a Mustang and expect it to live in this application.
Old 10-05-2009, 06:27 AM
3-fords's Avatar
3-fords
3-fords is offline
I know a T-5 is no good. I was looking at getting the parts from a truck at pull a part.
Old 10-05-2009, 01:05 PM
85e150's Avatar
85e150
The Mazda 5 speed would have OK ratios for this application, but probably wouldn't last long. The ZF would probably take the power, but really, you want a granny first gear trans in a sport truck?
Go find one to drive and sample the ratio spread and shift quality before you saddle yourself with one.
Old 10-09-2009, 09:15 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
A granny gear isn't neccessary in a single cab/short bed 2wd truck with a 351 and 4.10 gears.
Old 10-10-2009, 08:07 PM
92f150I6's Avatar
92f150I6
92f150I6 is offline
You could try to do a toploader 4 speed, but you wont have an overdrive.
Old 10-11-2009, 04:13 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
Personally, I would leave it with the E40D.
Old 10-11-2009, 12:53 PM
Jason Lewis's Avatar
Jason Lewis
Jason Lewis is offline
Old 10-11-2009, 05:25 PM
85e150's Avatar
85e150
Well over $2000. Maybe a Clark.....
Old 10-13-2009, 08:24 PM
96 ford f150's Avatar
96 ford f150
96 ford f150 is offline
hey im new to fords what rear end gear does a 96 ford f150 with the 300 inline 6 have it all stock
Old 10-15-2009, 08:12 PM
93F22A6's Avatar
93F22A6
93F22A6 is offline
I'm just curious as to why the T-5 is no good. What other 5 speed options (stock wise not looking to spend a lot of money)? (I have a 76 F-100)
Old 10-15-2009, 11:10 PM
96 ford f150
does any body know what gear i have in my rear end ive heard i had 4.11 rear end but im not sure it is stock and i think it is a 2.73 which is it
Old 10-17-2009, 05:42 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
I agree. A manual would be more fun but your options leave much to be desired.
Your year Ford F-150 came from the factory with either a 3.08 or 3.55 gear ratio. Look at the paper sticker tag on the inside of your door and read us the axle code. Or, crawl underneath your truck and look for a metal tag on a bolt on your differential cover.
Old 10-18-2009, 12:54 AM
96 ford f150
ok ill do both
Old 10-18-2009, 01:00 AM
96 ford f150
ok it say axle 17
Quick Reply: 5-speed in 93 lighning
