1.7 rockers for Gt40 HEADS
I've been reading around and havent really found if this is okay. Some of the rockers are able to be picked up some when the pushrod's are at the lowest point. Its not loose, but they do lift up some with the pull of your hand. The ones off the other motor dont budge. I found rocker shims in the box they came in, but im not sure if I should put those in or if this is how the rockers should be when the motor hasnt been run yet. Would it be okay to run the motor and let the lifters get primed with oil in them and then check the rockers again? or do these need shimmed?
so if you go with the 1.7 then you'll probably want to do a custom grind for the cam?
Would it make any difference if you were using gt40p's. with a stock cam and 1.7. I know the torque and comp ratio for the heads are different. Just wondering how the 1.7 rockers would play into that. It seems they would cut down on low end torq a bit.
Also, anyone have experience with high-end vs mid-grade valve springs and notice any difference between the two, or is it that the high-end springs are for heavily mod'd blocks?
mark1986F150
12-14-2012 07:37 AM
73 fourxfour
38
02-20-2011 02:55 PM
Home made SVT
11-16-2009 09:29 PM
hatemakings/n
09-16-2005 06:02 PM
TOUGHY17
11-06-2001 10:27 PM
