First Time Noob post
#61
#63
short update
Hey Grinner,
Been away from the shop for a while. The Cab is waiting for some epoxy primer. It's been too cold and wet around here for me to shoot paint on it. Ambient humidity is an issue in my part of the world. I don't have access to a climate controlled spray booth... so I make do with what I've got.
I picked up a 750 cfm Holley 4150 carb, an edelbrock streetmaster intake manifold(for the torque it's supposed to make), and a K&N Xstream air filter. It's all used stuff I bought off a couple of hotrodders. I think it may work for me with what I'm shooting for with the motor (some torque monster that puts out about 500+ HP on pump gas).
Here's a link on the Streetmaster 460 intake I found on FTE
https://www.ford-trucks.com/forums/8...arb-ideas.html
I'm a little concerned about the carb because the PO had the choke horn milled off. I did some research into this and it seems this was a common strategy 15-20 years ago before Holley came out with a double pumper with a ported main body. They call these their HP series 4150 carbs on the Holley site. So old hot rod and race guys would mill and port 4150 carbs to get more flow through the venturis. AT any rate if this carb was screwed by the milling job, I may just buy a new main body for it and rebuild the carb.
I've put the engine and tranny back in the chassis so I can test fit some headers this week. Then I plan to remove the engine & tranny so I can return to finishing the paint on the cab.
#66
Primered the console too.
Here's the console too. Its starting to come together.
I finally nailed down a color. I've ordered some basecoat and clear from the local parts store. I'm going with the original Limestone Green, or for those who love the Mustangs from 1973/4 the same color was called Medium Lime Green.
#68
#69
Color equals MASSIVE motivation.
Those tents work out pretty good huh. If you run across some of those bungees with the ***** on them...get extra...you will need them soon. Marine stores or good hardware stores will have thicker cord. The ones that come with the tents are junk.
I put together a good moisture extraction system for my compressed air. I read about it in the HAMB. I packed a coiled up air hose in a bucket of ice. Then I put a moisture collector/filter on the line after the ice coil. I finished up with an in-line mini filter/moisture trap just before my hvlp gun. So far so good. The water is staying out of the air line.
#70
#71
Sounds right to me. I would assume your going to paint the inside of the fenders,hood and doors. Possibly the inside of the bed so I think that sounds right.
I'm pretty sure Tim did 2 coats of color and 3 clear on my truck. It was a metallic though so I think it might take a bit more to get proper coverage. You can get a Sun gun which duplicates sunlight so you can be sure you got good coverage on the color.
Your going to want some touch up (maybe not a gallon though) for oopsy daisies when you reassemble.
Are you shooting high build on before you paint? Some kinda fun there. Always a joy to throw a straight edge on it only to find a few low spots that appeared from nowhere.
#72
Right now I'm prepping my fron quarters for primer. I've taken the emblems off and am having a little trouble with the emblem adhesive. Is there a solvent that works better for softening this stuff up?
I just don't want to go out and buy another can of some proprietary emblem glue dissolver. I know I'm cheap, but man I've got multiple cans of different thinners, solvents, pre wipes, final wipes, and degreasers kickin' around my shop right now. It's a good thing I don't smoke.
#74
Murphy's Law
Well Murphy's Law struck today.
The parts store I was going to buy the paint from lost the part I gave them to color match. I'm out one steering column beauty cover. They want me to give them another chunk off of my truck to send out for color match! I have to sleep on it tonight.
The part's not expensive or really difficult to replace. I think its the principle of the thing that makes me a little unwilling to buy from these guys right now.
#75
Paint Lesson #1
Well good news! I took delivery of my paint. The parts place found my color match part.
I learned my first paint lesson on adjusting the HVLP gun today. I spent sunday and part of monday evening wet sanding the primer on the hood of the truck. I was using too little air pressure and put big blobs of 2k primer all over the hood. It's OK... I think I got it fixed now.
