351M motor mounts?
Old 09-27-2009, 01:22 PM
Fordtrucksrule!'s Avatar
Fordtrucksrule!
Fordtrucksrule! is offline
351M motor mounts?
Are the motor mounts from a 1979 F-150 2X4 the same as a motor mount from a 1979 F-150 4X4? Both have the same engine, a 351M. Thanx for the info!!!!!!!!
Old 09-27-2009, 04:49 PM
dhigh45's Avatar
dhigh45
dhigh45 is offline
motor mounts should be the same.the motor perches will be different
Old 09-27-2009, 10:36 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
E1TZ6038A .. Right Front Engine Mount (Rubber Insulator) / E1TZ6038A replaced: D7TZ6038A & D8TZ6038C.
E1TZ6038B .. Left Front Engine Mount (Rubber Insulator) / E1TZ6038B replaced: D7TZ6038B & D8TZ6038D.
Fits 351M/400: 1977/79 F100/350 2WD/4WD / 1980/82 F150/350 2WD/4WD / 1978/82 Bronco.
The 1977/79 F100/350 2WD 351M/400 engine perches (aka towers, stands, supports) are the SAME as 1969/79 F100 302 & 1975/79 F150 302 engine perches.
But...
The 1977/79 F150/250 351M/400 4WD perches; the 1979 F350 351M/400 4WD perches and the 1978/79 Bronco perches fit these trucks only.
Old 09-28-2009, 12:05 PM
Fordtrucksrule!
Smile
Thank you for your information. You saved me some work and knuckle skin!
Old 03-18-2017, 11:44 AM
four-sixty-power's Avatar
four-sixty-power
four-sixty-power is offline
But...
Pretty sure THIS is why I am having the problem with lining up the motor mounts with the frame perches. Because the M motor mounts are year specific then it follows that the frame perches are different as well. My truck is a 1978 4WD f250 with 4spd trans and I am swapping a 351W into it, I followed the advice here on the forum that W will fit M frame perches if using the 302 motor mounts BUT on my truck the hole in the frame perches sits too close to the firewall by roughly 1/2" to 3/4" on passenger side, and maybe 1/2" on driver side. SO it follows that if the perches are different then the M motor mounts are different, so the hole in the perches will be different and that is why I have to drill a new hole in the frame perches. The W is in now, I swapped bellhousings and bolted everything in place but the 302 motor mounts do not line up, everything else fits fine and nice, I removed the motor mounts from engine and set them in the perch holes and then lowered the engine onto them to see if that would line up and it does not, so I have some drilling to do. I took pics but will get more after I get it bolted in, and post them all at once here. NOTE, the 302 engine mounts are the same part number, the same part for each side, there is no left and right for them, so swapping them side for side will not accomplish any change in location of threaded shaft going through frame perches.
mustang81
03-15-2018 09:50 PM
theboy558v
11-25-2017 02:31 PM
Justin Braun
03-14-2017 03:53 PM
winginit
06-21-2016 12:18 AM
justinkwitt
WTB - Parts & other
03-12-2016 09:08 AM
Quick Reply: 351M motor mounts?
