Installed new Window Switch...HELP!!!!!
ok soo i installed a new passenger side window switch and the problem is still occuring soo what could be next??? what else should i check?? like i said one day it will work fine and it will sit over night and then in the morning it might now work at all,when it works it works great but its just acting up now and it was acting up as much as it has this past week soo what ever it is it is getting worse..soo what would you guys check next?? does the power go through the driver side switch then jump over to the passenger side?? like what are some things i can check?? i rolled out the passenger side switch..whats next help please..??
I'm not an electrical guru, but you need to find a diagram of the wiring circuit. Then wait until it starts acting up and check the wiring with an ohm meter to look for a short. Either that or stick the meter on and wiggle the wires down the full length (kind of hard to do) to check for an intermittent short.
why not test the electrical connections when it's acting up (with a multimeter), and if they are good then it's the motor. I had a Camry with a motor slowing dying that would go down, but usually took an hour (and ten tries) to get it back up...
go to autozone and get a new motor then you can take that out of the equation.
ok well i took the door panel off and even tested the plug at the electric motor and it had power to i plugged it back in and the window worked fine all night and all day today and not tonight after my truck sat for a couple hours i got out to try it and nothing again..would a bad motor act like this??
