Flushing engine/cooling system after oil cooler failed
Old 09-20-2009, 09:01 PM
rickatic's Avatar
rickatic
rickatic is offline
Ok, my 04 lost its oil cooler last week. I have decided to take proactive measures and I am installing the ARP studs, MBRP turbo back exhaust, SCT, guages and new head gaskets. I have already done a EGR cooler delete. The heads are back from the machine shop and we will begin reassembly tomorrow. I have searched the forums for advice on how to best flush out the green goo from the entire system without any real success. Any advice on how best to do this. I have a gallon of Cascade to start with. I have wiped up as much as possible.
Ricatic
Old 09-21-2009, 05:36 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
I don't know that there is any good way to do it. It's a huge mess for sure. My advice would be to finish the assembly and add the Cascade as part of your initial "coolant" fill so that it can get started cleaning as soon as you start to crank the motor. If you have the radiator out you might try using Dawn in it while it's sitting but make sure the Dawn is all out before you install the radiator or you will have LOTS of bubbles. Other than that all you can do is just flush and fill until it's internally clean, probably multiple times.
Old 09-21-2009, 08:05 AM
rickatic's Avatar
rickatic
rickatic is offline
I have flushed the radiator with hot water and Cascade while waiting for the heads to be machined. I guess I will just brace for the mess.
Thanks
Ricatic
Old 09-21-2009, 08:42 AM
l-m tech's Avatar
l-m tech
l-m tech is offline
buy 2 botls of dawn dishwashing soap.the big bottles.pour a hole bottle in and water and drive20 - 40 miles.repeat this again then add coolant.there are 2 drain plugs in the block that you can remove after the second flush.
Old 09-21-2009, 09:11 AM
69cj's Avatar
69cj
69cj is offline
I also recommend you install a coolant filter asap.
Old 09-21-2009, 03:19 PM
Chris89lx's Avatar
Chris89lx
Chris89lx is offline
Simple green is what is used at the dealers.
Old 09-21-2009, 06:38 PM
Ford_Doctor's Avatar
Ford_Doctor
Ford_Doctor is offline
Simple Green does the job well. Here is a generalized instruction based on the TSB for cooling system flushing: Remove the thermostat, add 3 gallons of Simple Green and fill with water, turn the heater on too full heat, run the engine at 1200 RPM for 1 to 2 hours depending on how filthy the system is. Drain and flush clean, re-flush using Motorcraft cooling system flush and iron cleaner VC-9. Drain and flush again until clear. Replace all rubber hoses, the thermostat and the pressure cap. Refill system using Ford Premium Gold antifreeze 50% concentration.
Old 10-10-2009, 10:31 AM
psu927's Avatar
psu927
psu927 is offline
Hey guys does anyone have links of where to find all of the chemicals on the web?
Old 10-10-2009, 11:25 AM
rocky1074's Avatar
rocky1074
rocky1074 is offline
Simple Green: Wal-Mart; Auto Parts Stores;ect
VC-9 Icon Cleaner: Ford Dealer..
On Line: Motorcraft fluid for Ford Lincoln Mercury cars and truck
Make sure you use ONLY!! Ford Premium Gold Antifreeze
Coolant Filter: http://k-mansparts.com/items/motorcr...luids/list.htm
Old 10-10-2009, 09:15 PM
TreeTech's Avatar
TreeTech
TreeTech is offline
rickatic, I was in the same boat your in less than a year ago.. Cascade is not strong enough.. go with the simple green like others siad.. I got a gallon from Lowes. I flushed mine 12 times before refilling with coolant.. I would drain it every day or two. The hotter it gets the better off you are.. I drove my 04 to the beach on one of the mixes.. It was good and milky on that drain..
Old 10-10-2009, 09:24 PM
rickatic's Avatar
rickatic
rickatic is offline
When NCC... said it was going to be a huge mess he was not overstating. I am having a hard time believing what I am seeing. The amount of green gook is depressing. I am also having a problem getting heat. I have flushed the heater circuit separately and got a big glop of goop but still no heat.
Old 10-10-2009, 09:35 PM
TreeTech's Avatar
TreeTech
TreeTech is offline
How much oil did it dump in the cooling sys? I caught mine right away but it still dumped 2qts by then.. Ford dealers have replaced entire engines because of oil cooler failures. This was done because of too much oil contamination and not being able to remove it all..
Old 10-10-2009, 09:58 PM
bismic's Avatar
bismic
bismic is offline
Received 2,491 Likes on 1,728 Posts
"TSB 08-23-1 6.0L DIESEL COOLING SYSTEM CONTAMINATION FLUSH PROCEDURE" is interesting resding. If you would like a copy, I can send it to you.
Old 10-11-2009, 10:44 AM
rocky1074's Avatar
rocky1074
I want to flush my system, Just a couple questions...How much simple green did you add? Did you add some on every flush? Thanks
Old 10-11-2009, 10:53 AM
rocky1074's Avatar
rocky1074
Bismic Can you please send me a copy. You can PM me or e-mail it to me. THANKS mrrocky@wildblue.net
Quick Reply: Flushing engine/cooling system after oil cooler failed
