1986 F-150 Electrical Help!
Ok, As you can see i have an '86 f-150. It has the stock 5.8L H.O. $bbl. Carb and the Stock 100 Amp Alternator w/ External Regulator. Now i have been having problems with the battery charging. I tested the battery when charging and i get 12.4 - 12.6 volts. when the truck is off and i test the battery i get 12.1 - 12.2 volts.
Now i know that when the battery is charging it should be chaarging anywhere from 13.5 to 14.5 volts. So, i went and had the alternator tested at thrre different places and all three said it was good. this is the part were it gets tricky. I went out and bought three external regulators for it. the cheap one, the top of the line one and the stock oem matching one. while replacing the regulator the ignotion key was off and in my pocket and battery was disconnected. Unplugged the wire harness and replaces the regulator, plugged in wire harness, reconnected battery then started engine. Now one would think that this would solve the problem. But al three new regulators will not charge my battery. as a matter a fact when i check my battery while engine is running i get out of all three regulators a reading of 11.7 - 11.9 volts. i turn off my engine. and recheck my battery and i get 12.1 - 12.2 volts. so, i reinstalled my old regulator.
I really need some help figuring this one out Guys and Gals. I checked the wire harness and all things look good tested all wires and am getting no shorts of any kind. Please help!!!
on
Does the lights flicker when the truck is running? etc...
Also does the truck have a factory ammeter, or warning lamps for the charging system?
Alright i figured part of it out. Even though the three shops said that my aternator was good. i decided to completely disassemble my aternator. I found that the main brushes were very badly worn and were wearing uneven. so i ordered a set of new brushes and reassembled the aternator and i am geting 14.5v now. but i have still to figure out why it will only work with the original regulator. the new ones still won't work.
