Aux fuel tansfer tank pump
i have a 60 gallon aux fuel transfer tank that is currently gravity fed to the stock fuel tank and i want to install a fuel pump and use one of my aux switches to power it. my question is what fuel pump should i use for this??? will an electric fuel pump for a carbuerated engine work for this??
Thats what I use in mine. Don't remember the brand but I could get off my duff and go look. It flows about 1.8 gal. per min. Be sure and route your fuel line above the top of the tank a loop in the hose will work to prevent the tank from syphoning after the pump is turned off.. I also installed a gasoline in line fuel filter and manual brass shut off valve..
abyars111
15
09-28-2013 04:16 PM
