vacum pump
09-15-2009, 07:08 PM
on
vacum pump
has any one had any problem with the pump
mine will just keep running
do they ever go bad
tokk the lines off and there is some vacum but not alot
09-15-2009, 07:52 PM
on
what makes you think it is bad. is something not working???
09-15-2009, 08:13 PM
on
My 1st guess would be a leak somewhere causing it to think it needs to build the vacuum pressure back up and it runs constantly...
09-15-2009, 08:25 PM
on
Mine was running non-stop. I had a leak. Replaced 4x4 vaccum switch (which was cracked)and vac pump stopped running all the time.
txf350
1999 to 2016 Super Duty
01-24-2013 06:10 PM
timmosazz
07-24-2006 11:26 AM
akmud
43
03-05-2004 01:34 PM
otter2208
04-29-2003 04:15 PM
73 ,
diesel ,
ford ,
power ,
pump ,
stroke ,
vacum ,
vacume ,
vacumpump ,
vin ,
working
