Testing glow plug relay
I think it is based on the outside temp. If it is hot out (above a certain degrees oil temp above 70 ???) the PCM won't tell the relay to latch. Correct me if i am wrong but i don't think it activates on warm/hot days. I don't remember what the activating temperature was. But i always get the "wait to start" light reguardless of temp.
That seems higher of temp then when i messed with it last year. I don't remember it being that high. I messed with it last year and don't remember all the temperatures vs GPR time. I think mine behaved like Pats did. 90 degree, mine didn't activate either. I didn't have the AE back then but i shot the oil pan with my Laser Temp thingy.
What is states out of my Manual.
The glow plug system is electronically controlled by the PCM. If the temperature is below 55°C (131°F) the PCM will energize the glow plugs immediately after the key is placed in the ON position. Then, depending on the readings from the engine oil temperature (EOT) sensor and the barometric pressure (BARO) sensor, the PCM detdermines how long the glow plugs will be on.
Glow Plugs — PCM-Controlled
The glow plugs are located in the cylinder heads (6049), under the valve covers (6582).
The glow plugs are self-regulating. If the engine oil temperature is above 55°C (131°F), the PCM will bulb-check the WAIT TO START lamp but not energize the glow plug relay or control module.
The PCM system uses the glow plug module (if equipped) to conduct current to the left and right bank glow plugs.
The PCM protects the glow plugs by energizing them for short durations if the battery voltage is abnormally high.
The glow plug ON time varies from 0-120 seconds depending on battery voltage, engine oil temperature and barometric pressure.
On California vehicles the glow plug monitor (GPM) system is part of the On-Board Diagnostics II (OBD II) System.
The GPM system is designed to find failed glow plugs or failed wiring in the glow plug system.
A failure in the glow plug system will set a diagnostic trouble code (DTC).
