Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-14-2009, 10:57 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
Adjustable vacuum advance
I didnt know my vacuum advance was adjustable, but it is. Took the dist. to a friend's to check the advance curve on his Sun machine. When he took a look at what the vacuum advance did it was found excessive. We talked about it and the large amount of vacuum advance may be cutting into the mpgs. With the insertion of a small allen wrench into the nipple of the module, vacuum advance could be easily increased or decreased. He set it at 10 dist. degrees at a vacuum of 14.
Another thing happened about the same time. While he was on the Sun I was messing around with a parts dist. I took just in case extra pieces would be needed. Found that the dist. has aftermarket breaker plates riding on a full circle of ball bearings. Pretty slick for an old dist.
__________________
1946 1/2 ton with Y-block
1964 F-250, 292 4 speeed
1990 Ranger 4WD
1954 Model 600 tractor
  #2 (permalink)
Old 09-15-2009, 12:27 AM
wild.bunch's Avatar
wild.bunch wild.bunch is online now
wild.bunch is gaining momentum as a positive member of FTE. wild.bunch is gaining momentum as a positive member of FTE.
46: you are not adjusting the amount of advance by turning that allen screw, you are adjusting the rate.
What the screw does is change the tension on the spring inside the canister, so that you change the amount of advance you will get at a given amount of vacuum.
Check out this page:
AMOUNT
If you slide your mouse over the newer kind of advance canister, you will see how they describe using the allen wrench in the hose barb to adjust the rate of advance.
The pic next to it is the older kind, where you use shims to change the tension of the spring and adjust the rate. This seems harder to do, but being able to take the unit apart also allows you to change the spacer for a piece of tubing that you cut, so you can then also change the amount of advance. Here's a better pic of the inside of the older style:
OLDER STYLE
So by turning the screw, you will not change the maximum amount of advance the unit can provide. You will change the amount of advance at any given vacuum setting.
__________________
My Little Y Block Page
  #3 (permalink)
Old 09-15-2009, 01:02 AM
46yblock's Avatar
Thankyou for the link, I have put it in the favorites list. My vacuum cannister is just like the newer aftermarket, so we actually decreased the rate. I expect that to limit max a blocking method of some sort could be had (havent read the whole text yet). But, if I or we are right and the amount of vacuum advance seen on the Sun at 18 vacuum was excessive thus firing the cylinder too far down at cruise, and then decreasing mileage, we are on the right track (whew).
Please be mindful that I struggle to understand distributor advance and engine effect.
__________________
1990 Ranger 4WD
  #4 (permalink)
Old 09-15-2009, 08:51 PM
46yblock's Avatar
Here is a picture of the ball bearing supported breaker plates from the bottom side, and the vacuum advance that was in use. Note the straight arm on the vacuum unit. Are replacements available because this one is shot, and it would be nice to get the dist. back together and operational. Everything I am familiar with has the curved arm.
__________________
1990 Ranger 4WD
  #5 (permalink)
Old 09-16-2009, 03:52 PM
flipklos flipklos is offline
flipklos is starting off with a positive reputation.
Kinda off the subject here but according to what I just read I sould be using venturi vaccum. Not manifold vaccum? cause if this is the case I am hooked up wrong.
  #6 (permalink)
Old 09-16-2009, 04:03 PM
46yblock's Avatar
Quote:
Yes, if using manifold vacuum you would have a lot of vacuum advance added to the initial during idle. The 4V carb should have an attachment from a ported vacuum source.
I read Wild Bunch's site last night "Why do we need advance?" for about the 4th time. Each time it makes more sense. As an old supervisor from the past used to always say, about everything, "We're getting there".
__________________
1990 Ranger 4WD
  #7 (permalink)
Old 09-17-2009, 12:38 PM
85lebaront2 85lebaront2 is offline
1986 Ford F-350
85lebaront2 is starting off with a positive reputation.
46yblock, the early dual advance (centrifugal and vacuum) units Ford built had a factory ball bearing breaker plate. If you take the end off the advance (where the tube connects) there are shims, a spring, and a hollow sleeve. The spring was available in different strength, the shims allowed for fine tuning of the rate and the sleeve set the maximum advance by stopping the diaphram travel. Try a parts source that deals with restoration. The advance will probably fit 1957 to maybe 1959 V8 distributors, I had a couple of Lincoln 430 distributors like that. Look for the distributor number to help locate an advance for it. Good luck!
__________________
Bill Vose (Old School Hot Rodder)
1985 LeBaron convertible 2.2L TurboII
1986 F350 crew cab DRW 460ci
1986 LeBaron convertible 2.2L TBI (dead)
1986 Turismo 2.2 (race car)
1989 LeBaron J body convertible
1989 LeBaron J body coupe
1993 Grand Caravan 3.3L
1995 Lincoln Continental (project car)
http://www.oldschoolhotrodder.com
  #8 (permalink)
Old 09-17-2009, 03:18 PM
I had a port coming off the side of my holleys primary metering plate. I blocked it off and tapped off my manifold vaccum port underneeth. I belive it to be manifold vaccum anyways as it has a channel going to a spot bellow the throttle plate.
I have this setup wrong. So I have been underadvanced on the road? (The previous owner did also when he set up the 2bbl.) I just found out my distributor shaft bushings are bad and need a new dizzy anyways.
So block off this manifold port and tap my advance off the ported vaccum? Re-set my timing and I sould basicly pick up a few ponies and some milage?
Wow!
  #9 (permalink)
Old 09-21-2009, 12:01 AM
46yblock's Avatar
Quote:
I've heard references to the early ball bearing plates and think you may be right. Didnt have any idea of what they looked like, plus this one has a mfg. name of something like shrag. Maybe Ford farmed them out. Anyway the manner that the plate attaches to the body is not like later dist. I have a bonafide aftermarket ball bearing breaker plate for a mid '59 and later dist which cant mount to this body, nor can later stock dist. plates. Apparently Ford changed the design in mid'59.
__________________
1990 Ranger 4WD
  #10 (permalink)
Old 09-21-2009, 02:17 PM
THX1138-Z THX1138-Z is offline
THX1138-Z is starting off with a positive reputation.
Quote:
That ball bearing breaker plate was introduced in 1957 when FoMoCo got away from the LoadOMatic distributors. Early '58 model FE's also used it. The ball bearings are notorious for making wear spots in the race which in turn made the timing erratic. I use to just mark the bearing before removing it from the distributor and clock it a given number of degrees when reinstalling it to give a new spot on the race for the bearings to ride on.
  #11 (permalink)
Old 09-21-2009, 03:54 PM
46yblock's Avatar
Quote:
Thanks. Very helpful info.
__________________
1990 Ranger 4WD
Tags
adjusting , advance , baron , check , distributor , ford , le , setups , shimstyle , systems , timing , units , vacuum , vacuumadvance , yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
