Bent finger on pressure plate
Old 09-11-2009, 08:18 PM
Ultramagdan's Avatar
Ultramagdan
Ultramagdan is offline
I would trash it but then that's because I wouldn't want to drop the tranny to fix it again. To each their own and that includes baiting. A less is more attitude is recommended.
Old 09-12-2009, 07:09 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
Being an off road project, I would heat the finger and bend it back. I would probably put a heat sink on each adjoining finger (vise grip or clamp) and a thin sheet metal shield on each side before putting a torch to it.
I would put something underneath the adjoining fingers then heat it and push it down until it hit the "something" to make sure all the fingers were even with each other.
I imagine a clutch place that does class 8 trucks could replace just that one finger.
Old 12-22-2009, 04:37 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Question
Now im still thinking of just cutting it off... or maybe i should bend it.
Old 12-22-2009, 10:11 AM
'77fordtony's Avatar
'77fordtony
'77fordtony is offline
I wouldnt try to cut it off, the manufacturer put it there for a reason, and manufacturers dont like to waste material on something for no reason.
heating it up and bending it is a pretty good idea, except when you heat metal up, it loses its temper, or strength, afterwards. i think it would be pretty soft after doing that.
so i'd just try to bend it, and hope it doesnt break. if it does, then you got the answer to your question- cut it off. and hey, thats already taken care of.
so then throw it back in the truck and drive it to the parts store to buy a new one before it goes out.
Old 12-22-2009, 06:42 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
HAHAH!!! GOOD ONE, ya i like the point about the temper, i think i will just try to bend it, should have some spring memory in it still to get back to where it was made to be anyhow. i think it will last a good while still once i get it back in, i got nothing to loose but getting excersize taking it back out again anyhow right...
Old 12-22-2009, 06:45 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Best-case scenario if it fails is that it will rip the throwout bearing apart, and quite likely snap the hollow shaft it slides on. If that happens, there's also a good chance it'll snap the pilot nose off the input shaft and bend the input shaft. Is your bellhousing aluminum? Kiss that goodbye too. Now, just to save a buck, you need to replace a whole lot more.
What I want to know is who sold you that looking like that, and why do you even think it's remotely ok to repair?
Old 12-22-2009, 06:51 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
your crazy it wouldnt do that.
use your scare tactics on some elementary school girls cause they wont work on me.
Old 12-22-2009, 06:58 PM
andym's Avatar
andym
andym is offline
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.
The following users liked this post:
Old 12-22-2009, 07:04 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
what is with all the negativity around here? man, gees..
Old 12-23-2009, 12:13 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
Well, Mr. Glass Half Full, it's three months later and you are still posting about it? Get off the internet and put it back together so you can come back and tell us all how full of poop we are.....
Old 12-23-2009, 09:32 AM
'77fordtony
probably because he DID do try it 2 months ago, and it didnt work. so now he's pulling everyones chains.
the thing that irritates me is when people make honest suggestions to help someone out and they get put-down in return, bringing the thread nowhere.
this is a troubleshooting forum, not a high school chat room
obviously you must be smarter than anyone on this forum, so go outside and put your broken clutch in and let us know if it works
Old 12-23-2009, 01:14 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
maybe i will get to installing it this spring.. im not sure. im gonna try bending it without heat.
  #28
Old 12-23-2009, 08:55 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
So you're willing to take the chance it won't fail? You're also counting on me having never seen a similar failure, or that I've never had to fix the aftermath of this exact failure.
Are you willing to take the chance that this "cheap" used clutch will still work, and won't cost you more than the $140 or so a new clutch would cost?
  #29
Old 12-24-2009, 04:49 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Lifes about taking chances, i think it will be fine.. if not woopity doo..
  #30
Old 12-25-2009, 01:05 AM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
I really wish I had money to just throw away like that.
Hope it doesn't happen on a trail.
Quick Reply: Bent finger on pressure plate
