89 f150
89 f150
****** My sons buddy has a 89' f150 5.0, auto transmission, with intermittent running issue.
Sometimes it starts &runs fine. Sometimes it will start fine and stall shortly after, & not restart, turns over but no start.
Sometimes it will not turn over at all....just a click or 2.
Yes a tun up is in the works, just hasn't gotten it done yet. But...When it runs it runs fairly well.
They have tested the ignition module 3-4times, its fine.
grounds seem good.
They think that the alternator isn't charging correctly....(I'll agree ) when running, it will show on the amp gauge in side, that it is up to 14+ volts and a bit later ½ min er so , drops down to 8v. Appears to be a recently rebuilt one
I suspect also the relays on the DS of the upper intake maybe faulty.
What are those relays for and is there anything else to check???
thanks
grounds seem good.
thanks
for changing the PIP ...this is interior to the distributor? .do you need to pull the whole distributor up to change it?
or can these be changed without pulling the whole thing?
the relays , or what is suspect that they are. Are not directly hanging off the side of the plenum of the Upper intake, they are, (looking from the front ), off to the right 3-4 ", towards the rear of the engine.
If they are sensors or solenoids what are they for???
YES
YES
NO
Those are the three solenoid valves for the EGR valve and the A.I.R. system.
YES
NO
on
Those solenoids are for the smog equipment and won't prevent the engine from starting. First thing to do with one of these EFI motor is pull the codes, see www.fordfuelinjection.com for an easy DIY way to do this without a code reader. Sounds like the truck may have a bad battery and/or regulator, charge and test the battery and replace if it doesn't hold 12.5v, and change the regulator if the alt doesn't deliver a consistent 13.5v or better. The regulator is on the back of the alternator, it is cheap and relatively easy to swap out.
the codes that came up were 87 & 15
but still has a intermittent run-ability issue
check the plug behind the gauge cluster where the battery gauge plugs in, if this is loose it will intermittently charge the plugs that plug into the alternator are also known to go bad on the wiring harness so replace them as well and you should be alright-they sell the plugs in the electrical isle at advanced auto
