1967 F-100 project
Old 10-09-2013, 07:15 AM
67nukeford's Avatar
67nukeford
67nukeford is online now
Had some damage to the floor flange, where the kick panel welds on, so had to patch that.
  #77
Old 10-09-2013, 07:18 AM
67nukeford's Avatar
67nukeford
Patches are ready to weld into the kick panels. You can see in the second pic, the flange that I made with the bead roller. Almost a perfect match. Should have these welded in tonight.
  #78
Old 10-10-2013, 06:22 PM
67nukeford's Avatar
67nukeford
Kick panel patches are welded in, off to do the pasenger side.
  #79
Old 10-13-2013, 08:11 AM
67nukeford's Avatar
67nukeford
Pass. side is in. Didn't need as large of a patch on this one.
  #80
Old 10-13-2013, 08:14 AM
67nukeford's Avatar
67nukeford
Luckily, the weather held out long enough for me to get POR-15 on the cowl and floors. I'll be spraying epoxy over all of this. I'll probably just puff can some paint on the inner cowl, before I weld it back together.
  #81
Old 10-21-2013, 07:23 AM
67nukeford's Avatar
67nukeford
Coated the area where the panel will fit back around the rear window with Eastwood's rust encapsulator. I'll hit the spots around the rear window, and down below, where it gets welded back on, with weld through primer.
  #82
Old 10-21-2013, 08:05 AM
67nukeford's Avatar
67nukeford
Also been doing some sandlblasting with the cabinet. These are the pieces that weld to the back of the door supports. Pretty roached at the bottom, I'll be fabbing up som replacement peices for them.
  #83
Old 10-21-2013, 08:10 AM
67nukeford's Avatar
67nukeford
These are the boxes that go over the kick panel vents. I'll coat the insides with POR-15, then weld then on, and coat the outside with POR-15 also.
  #84
Old 11-12-2013, 04:37 PM
67nukeford's Avatar
67nukeford
So, thanks to my buddy Don from Oregon, I now have the inner sections of the cab corners! He cut these out for me, and shipped them down. So, I'll be getting these apart, and getting the new peices on.Thanks again, Don!!
  #85
Old 11-14-2013, 07:18 AM
67nukeford's Avatar
67nukeford
Worked on getting the in-cab tank hole filled. Cut out a piece of 18 ga. then welded it in.
  #86
Old 11-14-2013, 07:19 AM
67nukeford's Avatar
67nukeford
Re-installed the panel around the rear window. Began rewelding the million spot welds holding this thing in!
  #87
Old 03-11-2014, 08:32 AM
67nukeford's Avatar
67nukeford
Woohoo! Progress! Since it was in the 70's yesterday, took off a half day, and got some welding done. The panel around the rear window is welded back on, and most of the welds have been grounded smooth.
  #88
Old 03-24-2014, 08:44 AM
67nukeford's Avatar
67nukeford
Got the passenger side cab corner disassembled (these are the one's Don hooked me up with), and it's in amazing shape. I'm planning on using this sheet metal for this side, instead of the Dennis Carpenter peice, this one fits much better.
  #89
Old 03-24-2014, 08:45 AM
67nukeford's Avatar
67nukeford
Here is the inner panel that I really needed. I still can't beleive that the aftermarket doesn't make these, it would be simple for them.
  #90
Old 03-24-2014, 08:46 AM
67nukeford's Avatar
67nukeford
The drivers side is a different story. I removed the makeshift exhaust hanger that someone put here, for whatever reason. Not sure if I can save this outer piece, but I'm going to try. If I can, I'll sell the DC corners that I have.
Quick Reply: 1967 F-100 project
